Latest post 04-30-2009 5:26 PM by PhilLondon. 27 replies.
Page 1 of 2 (28 items) 1 2 Next >
  • 04-27-2009 6:15 AM
    Beovision 1 for link room, advise please
    Hi All,
    Just thought about the BV1 tvs as a solution for my bedroom. It would be nice waking up to some nice music in the morning, if I linked them to my ouverture/BV7, could I program it to start playing the Radio or CD from the link? Would the wireless 1 connection work with this TV?
    I know its 4:3, but coming from a BV7-40, would it look strange and unpleasing? I love the Avant (16:9), but its unfortunately too big for my bedroom.
    Please advise
  • 04-27-2009 10:35 AM In reply to
    Re: Beovision 1 for link room, advise please
    In addition, could people kindly advise if they have connected any media centre to it and how?
    Thanks heaps!
  • 04-27-2009 10:37 AM In reply to
    BV1 is an excellent TV. Awesome sound for that size and the picture quality is very good. There are some other posts on this forum regarding the qualities of BV1.
    Assume you will get the timer working from the link master.
    Wireless 1 should work, but that solution is expensive and less reliable than a ML cable.
    /Claes
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 04-27-2009 10:40 AM In reply to
    Thanks Hiort!
    I was searching for BeoVision 1 instead of BV1. Like you said there are loads more results!
    Are the BV1's reliable?
  • 04-27-2009 10:42 AM In reply to
    The Beolink Wireless would only transmit the sound and data (i.e. replace the Masterlink cable), but would not transmit the picture, so you'd still need the aerial cable.
    That said many people have been very desatisfied by their Beolink wireless.
    Do you plan to access video sources from the BV7?
  • 04-27-2009 10:44 AM In reply to
    timhanna:
    Wouldn't it be better to connect a media centre to the main TV and let it distribute it to link TVs...
  • 04-27-2009 10:52 AM In reply to
    Thanks Phil. I have a PS3 connected to my BV7 so it could be an option.
    Do you guys have one.
  • 04-27-2009 3:26 PM In reply to
    One last thing, with A.AUX work over the link?
    In order to watch the BV7 DVD, will i need a masterlink, RF cable and beolink video connected to the BV1?
  • 04-27-2009 3:35 PM In reply to
    Beolink video is only to convert TV with MCL connection to a ML network.
    Beovision 1, if they have a Beolink connection, should have a ML, so no Beolink video.
    Do you have a Masterlink plug on your Beovision 1?
    And which A.AUX are you talking about?
  • 04-27-2009 3:40 PM In reply to
    Hi Phil,
    Thanks for your continued help in this.
    The BV1 (havent got it yet) will have a ML connection on the back of it. Does this mean then all i need is a ML cable and a normal TV antena cable (RF coaxial) to get video to work?
    Will this mean that the PS3 wont work via the beolink or does the BV7 modulates it to RF?
    Update: A.AUX from the Ouverture.
  • 04-27-2009 3:45 PM In reply to
    Hi Tim,
    I have a bv1 in my bedroom linked to my avant dvd and overture and am absolutely astounded how good a tv this is!  They are also massive bargains at the moment.
    I would hardwire the set to your master as the cost of the wireless units outweighs the price of a cables
    Hope that helps
    Nick
    Filed under:
  • 04-27-2009 3:54 PM In reply to
    Thanks for the reply nickyg63!
    Does the 4:3 bother you? can you use the A.AUX on your ouverture over the link?
  • 04-27-2009 4:05 PM In reply to
    All sources of the Ouverture, including A.AUX will be available from the BV1.
    For the PS3, I am no expert, but the modulator of the BV7 may not be able to send HD signals into normal definition signals.
    It should work if you connect the PS3 to the TV's DVI or HDMI and through the Scart at the same time.
  • 04-27-2009 4:09 PM In reply to
    But a DVD on the BV7 would sent to the BV1 no problems right? In addition, have you used any media centre on the bv1? the apple tv wont apprently work without a modulator.
  • 04-27-2009 4:14 PM In reply to
    DVD, DVB tuner, HDR1/2, SAT work without problem.
    The problem only comes from HD source, like the Apple TV.
    You need to connect them at the same time to the HD input AND to a SD input (scart).
  • 04-27-2009 4:21 PM In reply to
    Great. Did you use a seperate media centre for the BV1 Phil, or did you link it to the main tv?
    My SAT box shows SD signals, but ive connected it with an HDMI cable, will i still need to connect the scart cable as well or does the tv only care that the signal is SD?
  • 04-27-2009 4:34 PM In reply to
    I do not have a BV1 but a MX7000 (even older) and I can get all the sources from my BV7. I do not have a local source on the MX. I do not have a Media center.
    For your SAT box, connect the HDMI and the SCART at the same time if you want the BV7 to transit the signal to the BV1.
    Basically the BV7 can only transmit sources connected to the SCART or the SD inputs, not the HDMI, DVI or Analog HD.
    (I feel like I am repeating myself).
    If you have a media center, try and make it work on the BV7, so you can enjoy it on 2 TVs.
  • 04-27-2009 4:39 PM In reply to
    Hi Phil,
    Thanks again. Don't worry I got it ;D
    Just need to do some "research" into what 4:3 looks like after being used to 16:9 and might go for one.
    Everyone's help in this has been really useful and helpful for me! Thanks again.
  • 04-27-2009 5:30 PM In reply to
    One more thing, the BV7 does not pass the Aerial signal through (the link out socket only send the link signal, but not the signal coming from the aerial). So you'll need an amplifier from B&O that is able to split and re-merge the signal... and somewhere to hide it!
  • 04-27-2009 5:42 PM In reply to
    Ok Phil,
    I officially didnt get anything there (i think its bed time for me ;P)
    Is it one of those beolink video things afterall?
  • 04-28-2009 4:35 PM In reply to
    timhanna:
    The set deals with 4:3 brilliantly as it shows 16:9 in the top 2/3rds of the screen so it doesn't look strange at all!
    A Aux works fine I believe I haven't tried it myself, I take it your connecting an ipod or similar.
    Cheers Nick
  • 04-29-2009 3:36 AM In reply to
    Thanks Nickyg63, if A.AUX works as well, it would be perfect and yes, connecting my imac :)
  • 04-29-2009 3:20 PM In reply to
    One thing that should be mentioned is the sound is awesome!!  Not as good as the avant but loads better than my mx7000 which is good!
    Cheers Nick
  • 04-29-2009 4:35 PM In reply to
    Thank you guys, really thanks for all the help. Because of all this help Ive finally bought one from my good friend Graham (beo4life). I havent collected it yet, but i cant wait!
    Now all I need is.... (i think).... masterlink cable, junction box (preferrably hub), RF antenna cable and RF Amplifier?
  • 04-29-2009 5:05 PM In reply to
    Can I ask you how you get your TV, analog terrestrial? sat?
