N-Music makes it compatible with your computer and Beoport software which enables you to play music which is stored on your hard disk.
The MK1 and MK2 can be upgraded for N-Music by fitting replacement software at minimal cost of around £20 plus fitting.
The upgrade is fully explained in a FAQ written by Keith Saunders.
