Latest post 04-30-2009 3:41 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 04-18-2009 4:02 PM
    WTB : Processor board or dump from a "virgin" board
    Dear members of this forum,
    I am seeking a unused processor board or even better a dump from it :)
    It has to be the "old" type with the sockets.
    Thanks in advance
    /PP
  • 04-18-2009 4:05 PM In reply to
    Re: WTB : Processor board or dump from a "virgin" board
    Hello,
    it might be helpful if you told us which unit the board you need is supposed to fit Big Smile
    -mika
  • 04-18-2009 4:31 PM In reply to
    Hello -mika and other,
    I am sorry for the less information :)
    It is for a Beosound 3000 - Type 2671
    Thanks in advance :)
    /PP
  • 04-30-2009 3:41 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    You should contact B&O, they will be able to help you with the code for your system.
    Bring proof of purchase and it will be no problem.
    And in danish;
    B&O i f.eks. Esbjerg (Gl. Vardevej 237) vil helt sikkert kunne hjælpe dig med koden til dit B&O system.
    Husk at medbringe købskvittering etc. så er det en smal sag.
    Som du allerede ved, kan du ikke få oplyst koden til dit anlæg her på Beoworld.
