Latest post 04-17-2009 11:30 AM by LarsBergen. 3 replies.
Page 1 of 1 (4 items)
  • 04-17-2009 9:38 AM
    How to program the radio on a Beosound Ouverture
    I read some place that the radio on an Ouverture is really advanced, and was therefore hopeing that i could program it to always start up on the same channel when i chose radio.
    1. How can I tune to FM 99.0 and store this under nr. 1 on thr radio
    2. How can I make the radio start up on this channel when I press radio on the Beo4
    Lars
  • 04-17-2009 10:35 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: How to program the radio on a Beosound Ouverture
    Hi Lars.
    The radio will always start on the last channel you used.
    Are you using a Beo4 or a Beolink 1000 to tune it?
    With a 1000, I think it is like this
    Radio
    Goto
    990
    Store
    1
    Store
    With a Beo4, it is a little more complicated, but still do-able.
    Andy T.
    Poor me, never win owt!
  • 04-17-2009 10:36 AM In reply to
    Why not upgrade your membership of this site to silver (£15) or gold (£30) and you can download the user manual and gain full use from your Beosound Ouverture.
    Regards Graham
  • 04-17-2009 11:30 AM In reply to
    It worked!!!!
    Thank you!
