I don't believe this, am still having fun with my mx7000. I think I should get the dumb beoworlder award
I'm trying to connect a Philips DVD player - which only has the three normal plugs out the back (Yellow, Red & White).
I've tried a Scart adaptor which got me nowhere, and got the feedback here the MX7000 wouldn't take the signal, which is cool.
So what I did - a small brain wave, was think how about using the camcorder bit on my V8000.
So AV1 = V8000, AV2 - Sky
So I select V.Tape, then select camcorder from the menu. All works fine, sound and vision, and then after a few seconds the picture starts dancing across the screen, and settles, this just carries on, making any DVD pretty un-watchable.
So what gives, is it an MX issue, or a V8000 or will the camcorder bit never stop jumping the picture?
