Latest post 04-13-2009 6:46 AM by rjb. 3 replies.
Page 1 of 1 (4 items)
  • 04-13-2009 3:41 AM
    • rjb
    • Not Ranked
    • Joined on 04-13-2009
    • Posts 2
    Paradise [ip] Beovision remote for 7802 tv
    Hello,
    My sister in law sent me her beovision remote control in the post to look at as it had stopped working (the fault was dry joints and a dodgy PP3 battery clip) but unfortunately when I first opened it the buttons fell out Surprise and I have no idea of the correct placement of the the four bottom buttons (see pic - I have just put them in in any position so I don't loose them) so could anybody tell me which button (step,volume,colour,brilliance) goes where (top left,top right,bottom left,bottom right) as I haven't got the tv here to figure it out on.
    Cheers,
    Rob.
    Bevision Remote
    Filed under: , ,
  • 04-13-2009 4:14 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: Beovision remote for 7802 tv
    Hi
    All the buttons should be diagonally reversed so you fro the top left have: Brilliance and color in the top row and volume and step in the bottom row
  • 04-13-2009 6:10 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    madskp is right - see picture below
  • 04-13-2009 6:46 AM In reply to
    • rjb
    • Not Ranked
    • Posts 2
    Cheers Guys!Big Smile
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
