Hello! Newbie here; so please be gentle! If I'm outta
line - or simply ask something which does not belong here - my apologies:
simply let me know ...
I have owned a Bang & Olufsen BeoSystem 2500 since they were
first sold in the early nineties (it nearly broke me!). Apart from a few
minor troubles along the way, it's been utterly superb and is used daily.
However, the vagaries of time have started to work their evil magic:
Either side of the CD and cassette trays there are (as
you'll probably all know already!) 4 bulbs illuminating these areas.
Unfortunately, the one on the right-hand side of the tape-deck has
started to flicker (I'm presuming a dry solder joint which I'm looking for
right now!) and a second lamp to the left of the cassette area appears to have
failed altogether.
Given that these appear to be fed from 6vAC and appear a little
out of the ordinary, I was wondering if anyone knew where I might obtain suitable
OEM and/or original B&O spares(?). I'm not averse to having a
professional repair if needs be but, given I've been constructing analogue
music studio and hi-fi gear for a fair few years now, I thought I'd save myself
some monies and effect a repair myself, where possible.
Also, some advice: sometimes the glass doors slide open on their own and
remain open, with the motor apparently straining, as if it hadn't sensed they were already open. They will not close by pressing the red standby button on
the remote or the red standby button on the unit itself, they merely remove power temporarily from the motor unit (<0.25s) which is audible as a dip in speed and volume. Only a
complete power-down works (the doors close on power-up). Has anyone else experienced
this? Sometimes, this will repeat itself many, many times and the only answer is for me to leave the power off for a while. Usually, the doors appear sluggish for a while subsequent to this fault. My principle concern is damage to the unit, especially the motor, which I've no doubt will prove impossible to source(!).
Finally - and I know this is a long post and a big ask - I have a
few (much) less important questions:-
i) Where can I obtain replacement speaker grilles / covers
from?
ii) Where can I obtain a replacement aerial from - my
daughter broke this a while back and I couldn't find a replacement then (and
B&O were actually quite snooty when I went in to their Birmingham
and Shrewsbury
stores and asked!)?
iii) Can the black, rubber sheet containing the buttons on the remote control accompanying the 2500 be replaced (again, my daughter pulled at one - the
"Reset" - and tore a quarter of it off!)?
iv) I have heard that there was an optional
(field-replaceable) RDS module available - around £85 at the time, if my fading
memory serves me well - for the radio. Any ideas where, if anywhere, I
could source one from?
v) Does anyone know of a reputable and local (West Midlands / Staffordshire / Shropshire ) serivce agent for B&O?
Cheers ... and I'm genuinely sorry for a long first post!
Steve.
