Hi Keith,
I ran the set up through the PCG & this is what came out.
I am trying to keep the naming & assigning simple for the kids etc, it seems that there are some caveats regarding connections & what go's where, is there a list for the available inputs & whats remaining after you have assigned a device etc.
Hope this makes sense
BeoVision 4
Beolab 3
DVD 1
DVD 2 (VR 1)
Set-top Box Controller ( 2 STBs )
Connection Video
Connect the VR 1 to the V.TAPE socket of the TV-set using a
21/21-pin A/V cable.
Connect the DVD-player to the AV socket on the TV using a fully mounted 21/21-pin
A/V-cable.
If your television is equipped with a built-in Dolby Digital module,
connect the socket marked DIGITAL OUTPUT on DVD to the input 1 socket
on your television (cable 6270775).
Connect the TV terminal of the Set-top Box to the TV DECODER terminal
using a fully mounted 21/21-pin A/V cable.
Connect the enclosed IR-transmitter to the IR-OUTPUT terminal on the back of
BeoVision Avant and mount the IR-diode above the Set-top Box IR-receiver.
Connect the television socket on the Set-top box to the television's
Camcorder socket using a Set-top box Camcorder A/V cable. Order No. 6270792
Connect the supplied IR transmitter to the IR-OUTPUT socket on the back of
your BeoVision Avant, and position the IR diode above the IR receiver of the
Set-top box.
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Connect the Beolab to the POWER LINK socket (FRONT) on the BeoVision
using a Power Link cable.
Both Power Link sockets contain left and right channel information.
The signal may be looped through to the second Beolab using another
POWER LINK cable and a Power Link adapter, part No. 6270597.
Setting switches on the Beolab
Set the MODE switch to position L or R to determine whether the
loudspeaker should serve as a left or right loudspeaker.
The Position and Setup switch on the BeoLab should be adjusted according
to the guidelines in the enclosed guide.
Setting of switch on DVD
Set the switch on the back of the DVD 1 (Y/C - CVBS - RGB) to position RGB
To ensure that the DVD discs are played with the proper picture format,
please perfom this "once only" operation:
Press LIST on Beo4 until v.setup appears in the Beo4 display.
Press GO to display TUNE. Press 1 if the DVD1 is connected directly
to a BeoVision MX television.
Press 2 if the DVD1 is connected to a BeoVision MX via an AV2 Expander box,
or if DVD 1 is connected directly to any other Bang & Olufsen television.
Press GO to store the setup.
Default is mode 1.
Selecting option on the TV-set
Option: OPTION 2, with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
2 | Observe confirmation
| from BeoVision
Programming the setup
Setup:
Procedure for the setting up of connected sources:
MENU / Setup / Connections
Fill in the menu as follows:
V.Tape AV Decoder
V.Tape DVD STB (SAT)
After filling in the menu, confirm the settings by pressing GO.
Now choose the desired Set-top Box on the list and confirm by pressing GO.
Set up connected sources as follows:
MENU / Setup / Connections / MENU
Complete the menu as follows:
Camcoder
STB (V.AUX)
