Hello everyone.
Planning a new home cinema setup based on BeoSystem 3 together with a projector.
I am looking for your opinions on choosing the center speaker and the need for a subwoofer.
The room is 3.5m (w) by 6.0 m length.
Considering BeoLab 9 as front and BeoLab 3 as back speakers.
The BeoLab 9 speakers will be placed close to each side of the new B&O cabinet (large), so the total width of the setup will be approx 2.5 meters.
I am uncertain of what to choose for a center speaker. Because my need of a cabinet underleath the projectorscreen, the 7-4 speaker is not possible. That leaves me with the choice of BeoLab 7-2 (equal width as the cabinet) or BeoLab3 speaker as a center.
QUESTION 1:
What is best match for the BeoLab 9 in this configuration, BeoLab 7-2 or BeoLab 3?
If your suggestion is BeoLab 3 should I use two (since I have to buy them in pairs) placed close to eachother, or just one?
In my livingroom I have i BeoVision 7-40 setup with BeoLab8000 front, 7-4 center and BeoLab 3 back together with a BeoLab 2 subwoofer, which I added recently. In this setup the BeoLab 2 contributed a lot, and made the sound much better.
QUESTION 2:
In my home coinema setup will I benefit (a lot) from adding a BeoLab 2 when using the BeoLab 9 as front speakers, or are the bass from the BeoLab 9 sufficient?
QUESTION 3 (a little off topic):
Does anyone have experience using different projector brands/models connected to the BeoSystem 3? If yes, which ones are you using? Suggestions?
Thank you in advance for your (insightful) opinions!
Roarmo.
