Hi.. im new to this forum, i've seen alot of information in this site regarding B&O products.. loves it!
I have a little problem trying to get my stuff work.. I have a BeoLab 1, BeoLab 2, BeoVision 5, Beosound 6000 and BeoSound 9000, and i cant get them work!
I've tried connecting 2 BL1s to the BV5 back panel into 2 X "front" socket, BS6000s - 2X "rear" socket, BL2 into Subwoofer socket all by powerlink and BS9000 by masterlink, doesn't seem to work at all..
I've tried switching off the power for the speakers to reset, but when i switch on the BV5, the red light of the speakers turned into green then back to red straight away.. doesn't seemed like they are properly set...
I've already looked through the settings menu on BeoVision, just wondering if there's any way or command on the remote that i can "synchronize" or do some settings to make them link up.. well anything that make it work please!
Best regards,
Arthur.
