Hi popester,
I'm not sure if your Pioneer receiver has pre-out sockets (RCA/phono/Cinch) on the back, if so you can easily connect Beolab 8000 speakers with standard RCA cables. Just set the speakers to "Line" mode using the switch in the hinged connection panel near the base.
If your receiver only has speaker outputs, then you will need Attenuated Cables to reduce the signals down to line level so that the speakers can accept them. Normal cables must not be used in this case, as the speakers will be damaged!
You can see more details of both types of cable by clicking on my sponsor link at the foot of this page.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
