Latest post 05-25-2009 2:33 PM by KingOfSnake. 22 replies.
Page 1 of 1 (23 items)
  • 04-03-2009 1:17 PM
    Beolab 8000
    I am considering purchasing these speakers, now can I add these to my Pioneer VSX-50 receiver, is this doable?
    Filed under:
  • 04-04-2009 9:11 AM In reply to
    Re: Beolab 8000
    Hi popester,
    I'm not sure if your Pioneer receiver has pre-out sockets (RCA/phono/Cinch) on the back, if so you can easily connect Beolab 8000 speakers with standard RCA cables.  Just set the speakers to "Line" mode using the switch in the hinged connection panel near the base.
    If your receiver only has speaker outputs, then you will need Attenuated Cables to reduce the signals down to line level so that the speakers can accept them.  Normal cables must not be used in this case, as the speakers will be damaged!
    You can see more details of both types of cable by clicking on my sponsor link at the foot of this page.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 04-07-2009 12:50 PM In reply to
    Re: Beolab 8000
    Can you recommend a pre-amp receiver to me that work for the 8000's and my Anthony Gallo's
    Filed under:
  • 04-07-2009 2:34 PM In reply to
    Re: Beolab 8000
    http://www.audiogon.com/cgi-bin/cls.pl?miscrcvr&1243612613&/Pioneer-Elite-ex-500-(vsx50/dv
    This is the receiver that I have, can I attach the Beolab 8000's to this or not, if not what can I do to be able to use the receiver and speakers? Logical answers please,
  • 04-07-2009 2:48 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Beolab 8000
    It seems to me that you have powered speaker-outputs and therefore you'll need the attentuated cables Steve mentioned earlier for the BL8000's.
  • 04-07-2009 3:26 PM In reply to
    Re: Beolab 8000
    hi
    when I look at the specifications for the pioneer i noticed that it had a subwoofer
    pre out you can use  this to connect your bl800 i presume the preout is rca plugs
    set your bl8000 to line on the switch on the back and try with low volume to see
    if it works
    regards
    jan
  • 04-08-2009 2:50 AM In reply to
    • Puncher
    • Posts 9,588
    Re: Beolab 8000
    Wouldn't this be just monophonic?
  • 04-08-2009 6:14 AM In reply to
    Re: Beolab 8000
    Hi puncher
    You may be right but as I cannot see the backpanel of the pioneer
    i dont know for sure but many amp's has a combinated pre out sub woofer
    connection
    regards
    jan
  • 04-08-2009 9:41 AM In reply to
    Re: Beolab 8000
    it does have a pre-amp subwoofer out on the rear panel, so what steps do I take for getting the right sound to come out of the Beolab8000's. I would think the sound will be low and little control.
    I'm sure an alternative approach can be made, please assist.
  • 04-08-2009 10:38 AM In reply to
    Re: Beolab 8000
    Hi
    has the preamp two rca connections if it has its probely a normal line out
    thats carries a variable signal out and can be used directly on bl 8000 in line position
    regards
    jan
    why dont you just try
  • 04-08-2009 11:04 AM In reply to
    Re: Beolab 8000
    It has only one rca out for the sub
  • 04-08-2009 3:59 PM In reply to
    Re: Beolab 8000
    hi
    then this solution wont work you have to get hold of b&0 box called i think
    mcl2av to connect to active speakers like bl8000 or an amp with variable pre
    amp output
    regards
    jan
  • 04-09-2009 3:38 AM In reply to
    • Puncher
    • Posts 9,588
    Re: Beolab 8000
    or you could use the attenuated leads both Steve and I mentioned below - they attenuate a normal speaker out level signal down to line level for use with active speakers!
  • 04-09-2009 3:49 AM In reply to
    Re: Beolab 8000
    They do make life easier - I use them to connect Beolab 6000 speakers directly to the powered outputs of a 1977 Beomaster 1900.  Sounds great and saves paying $$$ extra for an audio system with pre-out sockets! Cool
    Best regards,
    Steve.
  • 04-09-2009 9:07 AM In reply to
    Re: Beolab 8000
    Sorry for all this back and throw, the cables that are shown how would you connect to the Pioneer VSX50.  The connections for the speakers are not like this, do I have to modify them?
  • 04-09-2009 10:04 AM In reply to
    Re: Beolab 8000
    Hi popester,
    The Attenuated cables can be provided with any type of connections, the pictures on the website show the most popular one (2 pin DINs for B&O amplified Beomaster/BeoCenter models pre-1990) - feel free to ask if you need any assistance.
    Best regards,
    Steve.
  • 04-09-2009 12:22 PM In reply to
    Re: Beolab 8000
    Cheers mate
  • 04-09-2009 1:08 PM In reply to
    Re: Beolab 8000
    I was looking at an Onkyo TX-SR507, now this has a L/R line out, this should work with the BL8000's yes/no?
  • 04-10-2009 6:46 PM In reply to
    Re: Beolab 8000
    HI popester
    Only if lhe line out is variable that means variable volume but if its normal line out
    its a fixed one and cannot be used try to find out if is are eqiupped with pre amp
    variable
    regards
    jan
  • 05-25-2009 10:49 AM In reply to
    Re: Beolab 8000
    I have a Pioneer LX81 (european version of the SC-07) receiver and I want to connect a pair of Beolab 8000 to the LINE OUTPUT (ZONE 2 OR 3) at the Pioneer back pannel, but the question is: HOW CAN I CONTROL THE VOLUME OF THE BL 8000 ?
  • 05-25-2009 11:53 AM In reply to
    Re: Beolab 8000
    I am asking a similar question elsewhere on this forum.  If you plug into the RCA jacks on the BL8000 do you bypass the B&O built-in amp?  And how would this then work if I have my BL2 connected via Powerlink to the BL8000?
    Yes - then how do you control the volume?  Or would you need a pre-amp?
    -michael
  • 05-25-2009 11:54 AM In reply to
    Re: Beolab 8000
    Maybe the easy question that we can all relate to is plugging in an iPod - standard 3.5mm stereo output, variable volume/line-out (controlled with the iPod itself).
  • 05-25-2009 2:33 PM In reply to
    Re: Beolab 8000
    I am not familiar with the Receiver however if it has variable pre-amp outputs and you connect via RCA with the switch set to LINE IN then the amp controls the volume.
    @Michael - you are confusing too many issues IMHO - the sub is driven directly from a pre-amp with 5.1 outputs as are all the other speakers, the the amp in your setup determines volume.
