1st March February 2012
Latest post 05-17-2009 10:30 AM by TWG. 20 replies.
03-31-2009 1:52 PM
birgerbum
- Joined on 03-15-2009
- Posts 230
Re: USB Error - Please reconnect the Beo 5 and try again ... What's this?
HI twg
try to update your xp to servicepack3 if your copy of xp is illegal
download sp3 redist for developers from microsoft.com or from your
country dedicatet microsoft homepage because the language most be the same
as your xp
mvh
jan
TWG
- Joined on 04-17-2007
- Germany
- Posts 950
my XP is official.
Does the new configuration tool need SP3?
Oh and the Beo 5 is directly plugged in the computer (no hub).
TWG
- Germany
- Posts 950
Installed Servicepack 3 today and still the same error ...
StUrrock
- Joined on 02-04-2008
- Cambridgeshire
- Posts 219
Worked pefrectly on vista(honest copy) now I have the same problem. Have had to install config toll on another machine, until i have the time to reinstall everything on the vista machine and start from scratch.
StUrrock
- Cambridgeshire
- Posts 219
Thanks Jandyt will investigate and let you know.
TWG
- Germany
- Posts 950
very nice, but do you have a solution for me, too? :)
BeoEng
- Joined on 04-02-2009
- Struer
- Posts 1
If this problem occur ("USB Error - Please reconnect the Beo 5 and try again"). You shall undock it and then turn off the Beo5 (holding the center button down for 5 sek), and then dock it again.
Perhaps you have to do this a few times..
TWG
- Germany
- Posts 950
mmmh, today I used the "original" Computer on which it worked but there's the same error message :-(
I left the Beo 5 at my dealer, today. He should check it out and give it a try.
TWG
- Germany
- Posts 950
So, I've finaly found the solution:
Normal configuration without graphic icons works perfectly. When I'm adding my own icons to every zone, menu and light I get the USB-error-message or some times a "configuration too large" error message.
So it seems to be a bad software problem which shows that the Beo 5 doesn't seem to be perfect for icon based buttons :-(
That's a shame and I hope they'll fix it! I have so many nice icons made for the beo 5 :-)
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Are you sure that your BMP Icon files are no bigger than 100 x 44 each
If you get the message "Configuration too Large" means your "Configuration.XML file is greater than 2mb in size
How many Iccons have you added ?
TWG
- Germany
- Posts 950
Hi Keith,
yes, I'm 100% sure as the icon worked on Firmware 1.34a and config tool V1.3 :-)
I tried to use about 30 icons but even with only 10-15 I get this error message!? I can't understand that as it worked with the older software ...
Perhaps other members are interested in those icons, too? I could upload my whole set and other members can try it out.
TWG
- Germany
- Posts 950
Hi Keith,
I'm actualy uploading my configuration file but I always get an error message "Problem loading page" after clicking "upload xml file".
It is 3,2MB big - this seems to be the problem for the Beo 5 configuration tool; but personaly I don't think that there are too many icons!?
Is there any way to shrink it down?
Do you need the icons, too?
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
TWG,
Beo5 can only accept files smaller than 2 Mb. I think your problem is this. Try to send an xml file smaller, and see if you get the same error.
Regards
Keith Saunders
- Posts 3,810
I am sorry about the problem with the UPLOAD but the Perl server was down for a time, however it is all back working again now.
Please include in the zip file all the Icons as well as the configuration file itself.
As Quim has said your configuration file must not be greater than 2mb otherwise you will get the error.
TWG
- Germany
- Posts 950
Hi Keith,
no problem, now the icon upload worked fine! But I can't upload the 3,x MB configurationfile!?
I've attached all my icons. Perhaps some other members like them, too.
But please remove my photo out of the icons (I forgot it) ;-)
Now I have all the fine icons but I can't use them because of those limitations ... any workaround??
TWG
- Germany
- Posts 950
Hi Keith,
now my programming works with icons only for the zones and for the stations. It's not what I wished but it works.
My configuration file is still ca. 3MB on the PC but it transfers without problems to the Beo 5.
I can't realy understand this ;-)
Keith Saunders
- Posts 3,810
I cannot understand that either, unless your configuration file has a lot of duplicated data, which, when serialised is excluded from teh serilaised HEX file which is downloaded to the Beo5.
If you upload your configuration file HERE I will have a look at it
TWG
- Germany
- Posts 950
Hi Keith,
I've tried to upload the configuration file (3,6MB) on your link and it always said:
One or more files failed to upload
The reason was
File exceeded limitations : twg_beo5config.xml
Can I send you the file via email? Perhaps that's simpler ;-)
I think there's a bug in the configuration tool: When I reimport my configuration into the Beo 5 config tool, the description of my lamps is gone and I have double entries inside some zones ... Or am I doing s.th. wrong?
Greetings
Page 1 of 1 (21 items)
