Latest post 07-06-2007 4:42 AM by kawo. 77 replies.
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Re: User and Service manuals
The (frequently) asked for User manual of Beolink 5000 in French is now also available, (thank you Jean) i have uploaded it, as well as several MX user manuals. As soon as i figure out how to upload very large files, the service manual of LX5000-6000 and MX4000-6000 will be available as well.
BandOkie
- Joined on 04-16-2007
- Owasso, Oklahoma - USA
- Posts 112
I am looking for a service manual for Beolab Penta 3's. I need to find the piece to replace as the doors on the amplifier will not stay shut. I am getting them ready for a possible sale. Thanks, Michael
BandOkie
Michael in Oklahoma
BandOkie
- Posts 112
Also looking for the service manual for a Beosound Century. Thanks, Michael
BandOkie
Michael in Oklahoma
Peter
- Joined on 02-12-2007
- Posts 9,572
Don't have those at present but will keep looking. With regard rto the Century, is there any particular issue you are looking at? I do have a few bits and pieces I can maybe get for you.
BandOkie
- Posts 112
I am working on one and wanted to have a parts list. Parts related to the door and CD loading mechanismsm Thanks, Michael
BandOkie
Michael in Oklahoma
dornbirn2000
- Austria
- Posts 7
Hi all, It would be great to have a list which dvb-s receivers are working with the stb-c module of the BV 3. If I remember correctly the most recent table version is 3.6. Best regards edgar
Chris
- Joined on 04-17-2007
- Bredene near Ostend-Belgium
- Posts 143
Hi , Is anybody having a pdf file or picture of the Junction box sheet/manual inclosed with it?
Yes, I kown my spelling is horrible…
marcus_m
- Bavaria
- Posts 470
Hello all, I'm looking for a service manual for the AV5 Does anybody have one?
Thanks Marcus
Gerd
- Joined on 04-20-2007
- Germany
- Posts 523
I have the manual (without parts list) for BeoSound Century type 2651, 2652, 2653 and 2654 - file size is approx. 5,6MB @Peter Is there any way to upload it to the server (FTP)? Regards Gerd
Peter
- Posts 9,572
Possibly! I'll look into it. Or you could send it to me on disc, and in return I will send you a DVD with all my manuals on it!
Peter
- Posts 9,572
Got the scanner working but not happy with my first attempt! Service manuals are clearly going to be large - 10Mb + in pdf form. Plan to do the Beomaster 6000 quad first!
Jacoll96
- Posts 27
I see that the service manual for the Master Control Panel 5000 is available, but not the user manual. I'd love to get a copy of the latter. John
marcus_m
- Bavaria
- Posts 470
eduard:Is there nothing on Beoworld.org
Unfortunately not - at least I haven't found it.... There are some User Manuals, but no Service Manual :( I also had a look at the Avant Service Manual; I thought it could be a combined one as AV5 and Avant 50Hz are using the same chassis. Marcus
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Peter:Got the scanner working but not happy with my first attempt! Service manuals are clearly going to be large - 10Mb + in pdf form. Plan to do the Beomaster 6000 quad first!
Is the file size you quote after "Distilling" (adobe utility to minimise pdf files sizes)??
Peter
- Posts 9,572
Actually it turned out to be 6Mb and I have put it on site. Is it good enough? Not quite got the hang of the scanner yet - I need to flatten the pages more! Done it in grey scale though some of the diagrams are in colour but that would clearly make the files even bigger!
Puncher
- Posts 9,588
Peter:Actually it turned out to be 6Mb and I have put it on site. Is it good enough? Not quite got the hang of the scanner yet - I need to flatten the pages more! Done it in grey scale though some of the diagrams are in colour but that would clearly make the files even bigger!
I've had a bash at reducing the file size further (4.4mb) and it clearly impacts on the resolution of the schematic diagrams (obviously not acceptable in a service manual ) Does the scanner have the option to scan to a limited colour palette (256 colours) I would think the file swize would then be the same as greyscale?
Peter
- Posts 9,572
I got it down to 3Mb but was unhappy with the detail. The scanner is very basic! It was only £80 for an A3 scanner!
samueljoachim
- Bristol, UK
- Posts 42
Anyone have the service manual for the besound 3000 please? My doors are misbehaving!! Thanks
Joachim
Peter
- Posts 9,572
The 3200 is on, I think, which uses the same door mechanism.
samueljoachim
- Bristol, UK
- Posts 42
Peter:The 3200 is on, I think, which uses the same door mechanism.
Thanks Peter, I had a look, but unfortunately it does not cover the door mechanism: "This manual only contain the differences from the BeoSound 3000 to the BeoSound 3200. All other documentation can be found in the BeoSound 3000 manual." Great!! Cheers Anyone have any experience of taking the doors apart?
Joachim
Peter
- Posts 9,572
BS3000 service manual now on and looks pretty complete. Not sure why I didn't put it on before as it was on my computer! Clearly going senile!
samueljoachim
- Bristol, UK
- Posts 42
Peter:BS3000 service manual now on and looks pretty complete. Not sure why I didn't put it on before as it was on my computer! Clearly going senile!
Thanks (yet again) Peter
Joachim
