1st March February 2012
Latest post 03-28-2009 1:15 PM by Razlaw. 10 replies.
03-27-2009 4:41 AM
hampeman
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.33.88/avatar.jpg)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-13-2007
- Sweden
- Posts 40
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
In ATV, ver. 2.3.1 you can learn other remotecontols to contol ATV. It is possible to learn Beo4 to do it?
Edde![](http://forum.beoworld.org/emoticons/emotion-54.gif)
BMGHB
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.33.58/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 05-12-2007
- Posts 219
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Re: Apple TV Remote Control
hampeman:
No in short.
(edited: apparently you can...)
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
Razlaw
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.28.75/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-24-2007
- Illinois
- Posts 1,770
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
The answer is yes. I just did it. Connect an IR repeater and the Beo 4 commands will be learned. Works perfectly so far.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
beo-ap
![](/utility/anonymous.gif)
- Joined on 04-16-2007
- Posts 231
This is good news. What exactly do you mean by an IR Repeater, and where does that connect to ATV?
Razlaw
- Illinois
- Posts 1,770
I was referring to the cable that connects to the PUC out on the Beovision with an IR emitter on the other end. The emitter is placed over the IR receiver on the Apple TV just to the rigfht of the power light. It is the same cable used to control connected Blu-Ray players, satellite receivers etc.
BMGHB
- Posts 219
Are you sure?
So you say that the APPLE TV can learn IR signals from a Beo4 remote..??
You are not saying that the Beovision can control the APPLE TV..
Razlaw
- Illinois
- Posts 1,770
What I am saying is that if the Apple TV is connected to a Beovision with an IR Repeater through the PUC on the Beovision, just as a satellite box or or other peripheral unit would be connected, the Apple TV can and will learn to be controlled by the Beo 4 through the Beovision.
beo-ap
- Posts 231
I will dedicate some time to this project in the next few days. Thanks for the news.
Razlaw
- Illinois
- Posts 1,770
I would note that our Beovision 7 does not have the software update that includes Apple TV. The first couple of times I tried to get it to learn the commands I had the BV7 set to a VCRs and it did not work. I then changed the assigned device to a satellite box and it worked immediately. The up, down, left and right arrows will be learned easily and almost instantly. GO and MENU are a little trickier. They did not seem to want to be learned. I am thinking it may be because those buttons on the Beo 4 are for instantaneous single commands, not continuing commands such as the arrows. I did get it to work by pushing the button repeatedly at just the right speed while the Apple TV was learning. Also, I did not use the Menu button on the Beo 4 for Menu on Apple TV, I used green.
hampeman
- Sweden
- Posts 40
Which STB did you choose in the menu for STB boxes to control ATV?
Razlaw
- Illinois
- Posts 1,770
Samsung T351, but I have it assigned to V. Mem and use the V. Tape button on the Beo 4 to access it.
Page 1 of 1 (11 items)
