I have attached my Mac to V.MEM and want to listen to music from the Mac.
Before the upgrade to the latest firmware version the whole TV went into stand by a few minutes after P.MUTE. :-(
I got a firmware update to v4.74a and above issue is now fixed.
But now, a few minutes after P.MUTE, the IR commands are not forwarded to the Mac anymore. It seems that the IR command module goes to sleep. Only, if I re-enable the screen by pressing V.MEM, then IR commands are sent to the Mac nicely.
Can anyone confirm this issue?
Cheers,
Knubbi
Beovision 7-40 MK3, 2x Beolab 5, 2x Beolab 8000
