Hi guys
Right, i purchased a 2005 ex-display Beocenter 2 with DVD a couple of weeks ago. the first day i got it, it worked fine, then the next day, when i switch the unit on, i press load, opens up, i press close and DISC to load up a DVD/CD, and......nothing happens. even if i press the load button (on unit dvd/and Beo4), the red light flashes to say it has accepted the command, but will not open up for me to load a disc. have tried lots of different DVD/CDs but nothing works.
i have to switch the unit on standby, switch it back on, and press load, before it will open up i.e. i cannot press LOAD a few times when the machine is on to open the door more than once, i have to put it on standby then power it up again.
and it does nothing. it will play the radio and the sound i channel from the tv through the A.Aux, but i dont even hear it spinning the disc, i know it would be quiet, but there is nothing to be heard.
and the thing is, this is my SECOND ex-display from a B&O shop based down in england. they sent me a replacement unit by courier, and stupidly sent me two different socket boxes, and both of them i have hooked up to the head unit, but it does the same thing.
i am not being stupid, all the cables are plugged in, im not changing the settings, so what am i doing wrong.
I am seriously starting to be put off B&O becuase of this and other issues.....
Please help before i shout at the store.....
thanks
kevin
