Hi everyone
I'm new to this site and just acquired my first 2 pieces of B&O gear, a Beocenter 5000 with MMC20NE cart with Beovox S55 speakers and stands, and a Beomaster 1001 amp.
Both units seem to function correctly however there are a few cosmetic things I would like to correct, some help/advice would be great.
1. The beocenter turntable lid wont stay up, it falls down as soon as its been lifted up. Is this a broken or displaced spring? is there a usual symptom for this?
2. The beocenter 'programming' section aluminium lid dampning hinge has had the sides cracked off it so it no longer sits into the slot in the aluminium lid and frequently seems to cause problems when trying to close the lid, can this be corrected without getting the new hinge? if so, how would I do this?
3. The turntable runs silently but when the arm is being lifted or cue'd across the record automatically I can hear a slight metallic noise, is this something I need to be concerned about or might need attention? something I can look at myself with some screw drivers and a spare hour or so?
4. The beocenter turntable lid is quite scratched up, i used an automative 'scratch remover' from Meguires to polish it last night and it has come up better but not great, any suggestions on how to bring this up a bit better?
5. The Beomaster 1001 is missing the cover which goes over the 3 present FM tuning dials, any idea where I might get one of these from?
So far I am loving the Beocenter connected to my Yamaha NS-300 speakers, I will be sending the Beovox speakers off to a workshop to have the woofers re-coned (they are very faded) and refoamed in the next week or so and hopefully will have the complete system up and running in its former glory soon.
Andrew
