how easy is it to get replacement plastic / acrylic fronts for the BS 5000 family ??
http://www.beoworld.org/prod_details.asp?pid=717
I have one unit that I would like to replace the plastic front to, it is 42cm wide and 2cm high
What are they made of - acrylic, or some sort of hardened plastic maybe ??
Also what colour are they, when I shine a torch at it, it looks clear to me, but it could be tinted, I don't really want to remove it to find out, but I will if I know I can get a replacement easily !
