Latest post 04-09-2009 5:32 PM by Dillen. 8 replies.
Page 1 of 1 (9 items)
  • 03-15-2009 7:29 AM
    Beosystem 5000 Family - Front See Through Panel Replacements
    how easy is it to get replacement plastic / acrylic fronts for the BS 5000 family ??
    http://www.beoworld.org/prod_details.asp?pid=717
    I have one unit that I would like to replace the plastic front to, it is 42cm wide and 2cm high
    What are they made of -  acrylic, or some sort of hardened plastic maybe ??
    Also what colour are they, when I shine a torch at it, it looks clear to me, but it could be tinted, I don't really want to remove it to find out, but I will if I know I can get a replacement easily !
  • 03-15-2009 7:55 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beosystem 5000 Family - Front See Through Panel Replacements
    Just had a look at a Beocord 5000 I have in bits at the moment. There is a slight tint to it, also the Beocord has lettering set into the acrylic. Where it says "recording possible"
    CraigSmile
  • 03-15-2009 8:35 AM In reply to
    thanks Craig, is it a slight dark tint, a kinda greyish smoke ??
    also can you tell what it is made of , I am guessing some acrylic type of plastic, and how thick it is
    many thanks
  • 03-15-2009 8:37 AM In reply to
    • Craig
    • Posts 4,855
    It is what I would call a smoke tint, it is not very far off been clear. It apears to be a thin plastic from what I can see, although with it in place there is no way of telling the thickness.
    CraigSmile
  • 03-15-2009 8:58 AM In reply to
    good, I think it is probably 3mm or 4mm thick Perspex
    http://www.gcip.co.uk/pdf/perspex_new_colour_chart.pdf
  • 03-15-2009 4:46 PM In reply to
    • Craig
    • Posts 4,855
    ouverture:
    It's no where near that thick. More like 1mm having taken a closer look. Also I think it may be glass!!!
    CraigSmile
  • 03-19-2009 6:17 AM In reply to
    it is not glass Craig, I am prety sure it is  "Acrylic Glass" ,  aka  Perspex or Plexiglas
    http://en.wikipedia.org/wiki/Acrylic_glass
    I measured the front of my Beocord and the recess for the front panel ( the depth ) is between 3mm and 4mm
    Has anyone actually measured the depth with calipers a front panel on a 5000 family unit ??
  • 04-09-2009 4:25 PM In reply to
    can now confirm it is 3mm thick
    does anyone have a broken piece they can post to me by chance, I think I can get a single sheet of perspex the right colour, and provide a service ( at cost and p&p ) for replacement front panels for the 5000 family if I can get the colour right.
  • 04-09-2009 5:32 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Why not just get a good used original front panel ?
    Is it for a Beomaster, Beocord or ?
    Place an ad in the Private Wanted section.
