1st March February 2012
Latest post 07-12-2009 10:26 AM by yachadm. 25 replies.
03-07-2009 1:56 PM
Jandyt
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.58/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Beomaster 1600 Old type. Can't get in!
I have a BM1600 type 2113 (1970). It sounds lovely and the cabinet is near mint, but all sliders are crackly. Problem is, I can't get in the bloomin' thing! I have undone the four screws on the bottom, and one in each corner on the back. I was expecting it to slide out like a BM900, but it won't budge. Is there adhesive as well as screws? Any help much appreciated.
Andy T.
Peter
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.26/avatar.jpg)
- Joined on 02-12-2007
- Posts 9,572
Re: Beomaster 1600 Old type. Can't get in!
I have found the service manual for this one - it looks as though there are two screws on the front panel at the top. I am out tonight but I will scan the manual tomorrow for you - looks like a good one.
Jandyt
- Posts 13,004
Cheers Peter. I appreciate that. No screws visible, but we know what B&O are like for hidden things. The similar looking BM1400 doesn't seem to have any manuals either. Do you have those too?
Andy T.
yachadm
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.40.58/avatar.jpg)
![Top 100 Contributor Top 100 Contributor](/Themes/beotheme1/images/rankicons/rankTop100.gif)
- Joined on 06-24-2007
- Jerusalem, Israel
- Posts 687
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Andy,
Don't force it!
You've got 2 more hidden screws.
Remove the tuning knob.
Gently pry out the dialglass at the BOTTOM left and right corners, taking much care not to scratch it (I broke one plastic holder - don't you make the same mistake!).
Behind the dialglass, right at the top, you'll see 3 screws - only 2 attach the wooden panel to the chassis, but you can take off all three.
Then you pull the chassis forward and out of the wooden cabinet.
Next - I had a b*tch cleaning the sliding potentiometers, because they are completely sealed.
I had to completely remove them from the BM1600, then disassemble them, clean the inside, and reassemble them.
Photograph the wiring positions on each pot, before you desolder them.
It's not a job I'd relish doing again!
Best of luck
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
Jandyt
- Posts 13,004
Good on ya Menahem! I should have guessed you'd know the answer.![Yes - thumbs up](http://forum.beoworld.org/emoticons/21.gif) I wouldn't have forced it anyway, knowing what B&O are like for hiding screws. I guess if you found it a daunting job, it will be worse for me, a thicko! A bit like teaching a goldfish how to fix a carbuerettor. I will pull it apart anyway as it needs a damn good clean. You had some great pictures of yours, but they're gone since the server upgrade. I'll send a message to Keith and see if he can retrieve them. Take care my friend.
Andy T.
Peter
- Posts 9,572
Manual now on. I do have the 1400 one but am out playing tennis now so will probably start scanning it tonight. The 1600 is a nice manual!
Peter
- Posts 9,572
BM1400 service manual now on as well.
yachadm
- Jerusalem, Israel
- Posts 687
Andy,
Forget your "silly plastic cog" - I couldn't repair mine - it just broke again in a different place.
Its function WAS to provide weight to the tuning wheel.
So, what I did, was to get a couple of thick rubber washers, glue them together (vulcanizing glue) to make them even thicker, and then glue them onto the axle. The rubber washers' circumference contacts the tuning knob axle, and provides a heavy force-feedback when tuning - very nice simple substitute for the white cog.
I don't know how far you want to go in restoring it, but if you want to replace the wasted blue Philips axial capacitors, I have brand-new stock and can make you up a kit. These are very difficult to find on the open market, but I keep good current-production stock of these Vishay Philips axials.
Never buy NOS or any type of Old Stock of Electrolytic or Tantalum Capacitors - you'll just get into more problems when you install partially-or fully-dried-out capacitors in the circuit.
After you've replaced the capacitors, you'll need to measure the lighting voltage - it's AC, not DC, so you'll need a rectifier diode (a 1N4148 or 1N4002 is fine) to convert it to DC for an LED. Then if you let me know the DC voltage, I'll tell you what resistor you need. I can also let you have the warm-white LED's.
Here's a picture of the tuning wheel - if it can help you.
Menahem
Jandyt
- Posts 13,004
Thanks Menahem, but my prowess with a soldering iron is prohibitive! I have managed to replace bulbs with ones robbed from an already canibalised BM4000, thanks to Peter for providing both manuals.
Here is the plastic cog. You were right, it would have shattered again if I'd glued it together. I used a piece of clear plastic tubing to make sure the shaft stayed in situ and can manage fine without the weighty feedback from that heavy flywheel.
yachadm
- Jerusalem, Israel
- Posts 687
Hey Andy,
I have a question for you, for a change!
Here goes:
On my BM1600, I have an inconsistency on the actual Decoder PCB 8002083 vs the Service Manual's diagrams.
B&O couldn't help me with the inconsistency.
On the attached pic, you can see I have circled in yellow, 1 resistor and 2 transistors.
Could you have a look on your actual PCB, and tell me what you have for these 3 components?
Menahem
Jandyt
- Posts 13,004
Oh Menahem! You've no idea how difficult this was for me to do. Partly because my camera has auto focus that doesn't like close ups, partly because I have no technical expertise, and partly because my decoder is still in place, and if I unsolder it, I might as well chuck it in the skip, as I would never get it together again!
Anyway, here is the resistor, starting from the bottom (near the circuit board) Green, Blue, Red, Silver...
yachadm
- Jerusalem, Israel
- Posts 687
Andy,
Thank you so much, my friend!!!
So, the Service Manual is definitely misprinted on these components!
Just as well that you didn't have to develop all 20 photos!!!!
Actually, the PCB's are not soldered, they are held in by friction claws, and can be removed by pulling firmly upwards!!!
Menahem
