How do I check usage stats on 33xx models, such as the two-way mx4000? Menu 00 play only shows the s/w version (on the 39xx models (like the lx5500) you also see the usage counters).
Thanks,
Henrik
As far as I know there are no such counters on the 33xx models
This is not quite correct. The later MX4000/6000 had counters.
V1.0 and V1.1 has no counters, this would right.
V2.x has counters. Almost like this MX5500... my camera is damaged so i use this picture
Ah, ok! So there is v2.x software for these models? And being 33xx, they still will be two-way, right?
Anyway, thanks for your answers - now I know I was looking for something that doesn't exist! :-)
Wait...
MX4000/6000/7000:
V1.x is two-way.
V2.x and higher is one-way.
Only MX3500/5500 is always two-way...
