Latest post 03-01-2009 10:50 AM by henrik. 5 replies.
Page 1 of 1 (6 items)
  • 02-26-2009 3:36 PM
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Q: How to check usage details on mx4000/6000/7000 s/w 1.1?
    How do I check usage stats on 33xx models, such as the two-way mx4000? Menu 00 play only shows the s/w version (on the 39xx models (like the lx5500) you also see the usage counters).
    Thanks,
    Henrik
  • 03-01-2009 9:15 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Q: How to check usage details on mx4000/6000/7000 s/w 1.1?
    As far as I know there are no such counters on the 33xx models
  • 03-01-2009 9:22 AM In reply to
    This is not quite correct. The later MX4000/6000 had counters.
    V1.0 and V1.1 has no counters, this would right.
    V2.x has counters. Almost like this MX5500... my camera is damaged so i use this picture
  • 03-01-2009 9:30 AM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Ah, ok! So there is v2.x software for these models? And being 33xx, they still will be two-way, right?
    Anyway, thanks for your answers - now I know I was looking for something that doesn't exist! :-)
  • 03-01-2009 9:58 AM In reply to
    Wait...
    MX4000/6000/7000:
    V1.x is two-way.
    V2.x and higher is one-way.
    Only MX3500/5500 is always two-way...
  • 03-01-2009 10:50 AM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    But 33x are always two-way, right? (I guess this means that they run 1.x s/w)
