Latest post 02-27-2009 4:18 AM by James Chen. 4 replies.
Page 1 of 1 (5 items)
  • 02-26-2009 5:52 AM
    Beosound 2300 need to warm up so it will play CD
    My Beosound 2300 is quite old and acting cranking lately, CD won't play if I don't play the radio for a while and then switch to CD...I feel that CD player needs to be warm up !! Has anyone has similar experience...and since it is quite old...does it worth fixing...any suggestion ?
    Thanks,
    James
  • 02-26-2009 7:09 AM In reply to
    Re: Beosound 2300 need to warm up so it will play CD
    I'm not very technical I'm sure Keith will give you a great answer soon, but maybe the BS 2300 is suffering from bad capacitors?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 02-26-2009 9:37 AM In reply to
    Do you normally leave it on standby when you are not using it?
    Regards Graham
  • 02-26-2009 12:15 PM In reply to
    Needing to warm up makes me think of cracked solder.
  • 02-27-2009 4:18 AM In reply to
    Yes I do leave it on standby and let it switches off automatically sometimes.....and to my surprise....I don't have to warm it up today, but I am sure it will happen again as it's been going on like this for months. I guess my Beosound 2300 must over heard my discussion at B&O store about retiring it by using link or wireless to hook up BS9000 in living room.
    James
