I'm the happy owner of a beo 5 remote and downloaded also the config tool.
My dealer gave me the config they made for it so i can adapt it for my own needs.
I want to tune it for my domotica system (domintell) addressed via a Lintronic box.
all this is working fine and easy to configure.
i have/had some problems :
1) the dealer configured the BV9 with beomedia an hd-disk recorder + telenet cable receiver.
the cable receiver is addressed via v-aux and not via DTV.
(no problem for the beo 5, but we also use beo4 in the house, so it should be better connected on the DTV button.
I saw that you can not choose DTV button in this setup for the external digital receiver when you choose the european version
of the BV9). When i choose the BV9-US version i can connect it to DTV, so problem solved, but it is rather strange that you can not
do it with the european BV9 ....
2) the config file i received does not have all the logo's in it.
I see in the xml file, they are pointed in the directories, a bit stupid for me, because the config file only works 100 % if you have all
logo's with the same name on the right place...
an enhancement could be to make a separate file with all logo's in at the moment the config file is generated.
3) everytime when i change a connected device, for example i change or add a DVD player, it deletes completeley the config made for other
buttons .... this is really annoying... Is this normal ? I guess i'm doing something wrong ?
4) I used the telenet digital receiver setup, I created a new screen for all the channels and added some logo's.
THe IR code needed for the telenet box for the "channel up" button is "PLAY + channel UP"
When I'm in the channel screen, the channel up key is sending another code (standard IR TV channel up)
I changed this also to "PLAY + channel up" and this works fine,
So i can change channels with this key when i'm on the screens with all the logo's.
When i do the same for channel down it does not work, it still is sending the old IR code.
When i opened the xml file, i saw that for that key stroke, there were two settings ...
the old one and the new one i created.
So i think this is a small bug ? Anyway when i deleted the old line manually in the xml file it accepted my line
and it worked.
nico
