I got a defect VX7000 which showed 88:88.
There is still a tape stuck in the machine. I was told that it just stopped working while it was playing.
I went to the powersupply and the 4 main big caps were all defect, leaking and so on.
1 3300uf 25v
1 2200uf 50v
1 1500uf 35v which I undestand is rare but I got a back of Nichicons the other day which are the same 105 degree type.
1 2200uf 25v which was placed next to the 1500uf 35v.
I got a problem here as to what the Die Bogener says about what caps to use.
There is the 1500uf 35v and 2200uf v25 as the original ones in the powersupply as I found out.
In the workshop for VX7000 it's 2 of the rare 1500uf 35v instead.
As I'm about to install 4 new caps could somebody correct what actual caps is the right type to use?
