Latest post 06-05-2010 4:37 AM by ASud. 13 replies.
Page 1 of 1 (14 items)
  • 02-23-2009 10:33 AM
    Maintenance Mode
    Hi all,
    could anybody tell me how to put the BM5 in maintenance mode so that I can access windows??
    Beodude
  • 02-23-2009 2:57 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Maintenance Mode
    When you have the main menu - press MENU - 9 - (Configuration) - 0 - 0 - GO - Maintenance - GO - Service menu.
    Stefan
  • 02-23-2009 7:23 PM In reply to
    Thanks for this Stefan Yes -  thumbs up
  • 02-24-2009 6:02 AM In reply to
    • stefan
    • Posts 1,733
    You`re welcome.
    Stefan
  • 09-19-2009 5:30 PM In reply to
    I am aou to install a USB wireless adapter to connetsmy BM5 to my network. This requires that i enter the service menu but how do i navigate in Windows (mouse and keyboard)?
  • 09-20-2009 8:42 AM In reply to
    • stefan
    • Posts 1,733
    You can connect an USB keyboard and mouse to BM5.
    Stefan
  • 10-02-2009 4:19 PM In reply to
    Hi
    is there a way to access the menu from the beosound 5 itself? i sort of remember the technician pressing 'right' 'left' 'right' 'go', but i can't remember the exact way.
    thank you so much
  • 10-02-2009 5:18 PM In reply to
    • stefan
    • Posts 1,733
    Try  right - left - right - left - GO.
    Stefan
  • 10-02-2009 5:39 PM In reply to
    is that under mode - settings - maintenance? it still doesn't work.
    hmmmm, it's frustrating me now.  the dealer has said he would come round for 5 weeks now, and he hasn't come yet.
    if you find out, please let me know, i tried the formula you gave above with the numbers, but that will only access ther service menu on my tv for tv and dvd.
    thank you so much again
  • 10-03-2009 5:51 AM In reply to
    • stefan
    • Posts 1,733
    Sorry - yes, go to SETTINGS, press right - left - right - left - GO. Now you can choose different menus, for example SERVICE MENU.
    Use the lever, wheel and buttons on BS5 - NOT Beo4.
    Good luck
    Stefan
  • 10-04-2009 5:52 AM In reply to
    Stefan, you are a GOD!
    Thank you so so much. I've done it.
  • 06-03-2010 5:55 PM In reply to
    • ASud
    • Not Ranked
    • Joined on 11-01-2009
    • Posts 19
    I have tried this and got to the maintenance mode - where can I find the IP address? Which section I tried looking but cannot find it? I remember reading on this forumn that you should be able to find the IP address from this mode? If not how else can I find the IP address?
    Also how do you exit this mode?
    Thanks,
    Arvind
  • 06-04-2010 2:13 AM In reply to
    • Alain
    • Not Ranked
    • Joined on 10-22-2009
    • Bierbeek, Belgium
    • Posts 9
    On the maintenance menu, select "Network Info" (third choice from bottom up).
    The third item is "IP Address".
    To exit from maintenance menu, select "Mode" (first choice), then select "N.Music" or "N.Radio".
  • 06-05-2010 4:37 AM In reply to
    • ASud
    • Not Ranked
    • Posts 19
    Thanks got it now - should be looking properly!
    Arvind
