Latest post 05-28-2007 5:16 AM by Tom. 10 replies.
Page 1 of 1 (11 items)
  • 05-27-2007 3:00 AM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Beovision 4.Which size?
    Hi,  I'm currently looking at purchasing a used or new BV4. The question I have is which size is best for my room. This would be my first panel TV.
    The distance between me when sat on the sofa and the front of the panel would be around the 8ft mark. Would you go for a 42 or a 50 BV4?
    Some advice from BV4 owners would be most helpfull.
     Cheers.
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
    Filed under:
  • 05-27-2007 9:11 AM In reply to
    Re: Beovision 4.Which size?
    The 42" is not in the market anymore in Europe, used you can find it sometimes. They are selling a few in the US but would think that ends soon as well when the panels are upgraded to full HD.
    That said, I would think 42" is suffficient, personally though I prefer bigger screens for movies. So big that I have a projector.
    JK
  • 05-27-2007 9:49 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    8ft?! Wow you may want to move the couch back a bit if your considering a screen any larger than 32". Larger screens are for larger rooms.
  • 05-27-2007 10:05 AM In reply to
    We watch our 32" avant from a distance of about 12 ft (4 metres) and would not consider watching anything above 42" from this distance. I don't think you can enjoy watching a 42" screen from a distance of only 8ft (about 2.5 metres) you would have to move your head from sided to side and up and down the screen to take in the details of the image!. Consider a smaller screen and moving that couch back a touch.
  • 05-27-2007 10:31 AM In reply to
    • David
    • England
    • Posts 128
    We have a 32"Avant in our main room which is the hub of our B&O equipment. The plasma screen will be for a second lounge for the kids. This room measures 11ft across but the viewing distance is around 10ft not 8ft as previously mentioned.
     The TV has to be wall mounted hence a plasma or LCD. We already have a 22" BV6 in the kitchen which would be to small for the kids lounge.We also have BV 1's in the bedrooms but they look to dated now to have downstairs.This only leaves me with the option of a used 42" BV4 or a new 50" BV4 which I think would be way to big.
    Do you think the 42" would be ok?
  • 05-27-2007 5:08 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    sorry, double post. please delete this one
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-27-2007 5:09 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    in general, you should count 10" of screen per 3 ft of viewing distance. This would even make a 32" screen quite big for your room. I think the 40" BV7 would be a good solution if you absolutely want a big screen. Don't go for a 50" screen, viewing with to little distance will cause headakes and you won't enjoy the picture quality as if the distance was bigger.
  • 05-28-2007 2:38 AM In reply to
    • David
    • England
    • Posts 128
    Thanks for the input gents. I think the 32" BV7 would be ideal, although the DVD is a waste on it for me because this TV would be connected to my Avant DVD. I wish B&O would make a BV6 in a larger size.
     Thanks,
    David.
  • 05-28-2007 4:41 AM In reply to
    Hi David,
    have you considered a BV8 in 32"?
    Marcus
  • 05-28-2007 4:56 AM In reply to
    • David
    • England
    • Posts 128
    Is the BV8 available now?
  • 05-28-2007 5:16 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    dwrights:
    no, the BV8 is not yet available in 32", but I am sure that it will be within the next 6 months, as it has been announced in the financial report
