I hope someone can help me with this:
I still have a Beomaster 2000 (the 80s model) in daily use. It is in perfect out-of-the-box state, without a single scratch. It really looks like it was manufactured just yesterday and still works great.
But as a perfectionist I have a real problem with the only optical fault: The original red-transparent adhesive tape for the Source LEDs became loose on some spots and there is air under it. I added a picture so you understand what I mean.
Unlike in the 1900, in the 2000 there are no colored plastic covers above the lights, it is just a adhesive tape taped over the cut-outs in the glass from the inside.
Where can I get that tape? As I mentioned it is some sort of transparent red tape.
I am also looking for a green one for the Stereo and the Tuning calibration LEDs.
