Latest post 03-03-2009 11:52 AM by nmartin771. 11 replies.
Page 1 of 1 (12 items)
  • 02-21-2009 9:19 AM
    R/L speakers problem ?
    One strange thing happening.
    My system: BL8000 connected to BC1 - masterlink to converter and than to AUX on BS2300.
    I setup BL8000 , L for left and R for right speaker. When I'm playing CD from BS2300 right speaker is little bit more quiet than the left one.
    When I setup right speaker to L than is ok.
    This is only happening when I play CD or radio from BS2300 ( when speakers are setup L-left R-right),  when I playing other source TV, DVD, or from PC (which is connected to the SCART ) everything working fine!
    Anyone know what is happening ? Maybe some setup on BS2300 ?
    Thanks!
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 02-21-2009 4:10 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: R/L speakers ?
    Is the balance set correctly on the BS2300?
    CraigSmile
  • 02-21-2009 7:30 PM In reply to
    Re: R/L speakers ?
    YES !
  • 02-22-2009 4:41 AM In reply to
    Re: R/L speakers ?
    And nothing happening when I adjust balance or sound on BS2300
  • 02-22-2009 6:57 AM In reply to
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    Re: R/L speakers ?
    It's normal that you get nothing out the sound settings on the BS2300 when you have a TV hook'd up and it's running on Option 0. The TV controls it. As for the issue it self.. i don't know, no advice here. Maybe try to connect the Speakers to the BS2300 and program Option 1, just to test if it is the 2300 or ML - Cable / Converter.
  • 02-22-2009 12:56 PM In reply to
    Re: R/L speakers ?
    Maybee datalink cable that comes from BS2300 to converter ....
    I dont know ....
    Maybee someone had similar problem ?
  • 02-27-2009 2:04 PM In reply to
    Re: R/L speakers ?
    So, I tried everything, checking cables, converter .... but still when I'm playing from BS2300  right speakers is little quiet than left one ...
    Anyone have idea ?
  • 02-28-2009 7:20 AM In reply to
    Re: R/L speakers ?
    I think I should wait for Keith to see this post .... Smile
    come one Keith where are you Sad
  • 03-01-2009 2:14 PM In reply to
    Re: R/L speakers ?
    In Keith's absence, maybe I can help?
    Firstly, check all your cables are pushed in firmly and try all speakers on both channels (flick the switch from left to right channel) to see if the problem is present on all of them.  This sounds like a poor connection, either in the source unit, one of the cables, or a speaker.
    If you have a spare cable, try swapping out the existing cables one at a time, as this may help you identify the source of the fault.  Basically, if changing a piece of equipment makes the fault go away, then that piece of equipment is probably at fault.
    If you can give us a little more detail about how your speakers are connected together, this may shed some extra light on how we can help.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 03-01-2009 2:34 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: R/L speakers ?
    Sounds like it could be the ML cable or an ML junction (if there are any) - there is a possibility that either pin 15 or 16 could be either down entirely or at least faulty.
     Weekly top artists:
  • 03-01-2009 2:50 PM In reply to
    Re: R/L speakers ?
    Hi Steve and Alex,
    Thanks for trying to help....
    So, my speakers are connected to BC1 - digital back (surround sound back) left one is conected on left PL plug and right on is on right....and then from BC1 - ML cable to converter 1611 - from 1611 data cable to aux on BS2300.
    I've checked data cable from BS2300 ( I have spare one so I've changed and nothing happened) and it seams to me this is not a problem. Also powerlink cables are ok cos when I playing from other source everything is ok.
    I didn't check ML cable, I don't have spare one ....
  • 03-03-2009 11:52 AM In reply to
    Re: R/L speakers ?
    no one ?
    Still waiting for Keith .... Smile
