1st March February 2012
Latest post 03-03-2009 11:52 AM by nmartin771. 11 replies.
02-21-2009 9:19 AM
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
One strange thing happening.
My system: BL8000 connected to BC1 - masterlink to converter and than to AUX on BS2300.
I setup BL8000 , L for left and R for right speaker. When I'm playing CD from BS2300 right speaker is little bit more quiet than the left one.
When I setup right speaker to L than is ok.
This is only happening when I play CD or radio from BS2300 ( when speakers are setup L-left R-right), when I playing other source TV, DVD, or from PC (which is connected to the SCART ) everything working fine!
Anyone know what is happening ? Maybe some setup on BS2300 ?
Thanks!
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Is the balance set correctly on the BS2300?
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
nmartin771
- Novi Sad, Serbia
- Posts 3,103
And nothing happening when I adjust balance or sound on BS2300
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Maybee datalink cable that comes from BS2300 to converter ....
I dont know ....
Maybee someone had similar problem ?
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
So, I tried everything, checking cables, converter .... but still when I'm playing from BS2300 right speakers is little quiet than left one ...
Anyone have idea ?
with grappa !
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
In Keith's absence, maybe I can help?
Firstly, check all your cables are pushed in firmly and try all speakers on both channels (flick the switch from left to right channel) to see if the problem is present on all of them. This sounds like a poor connection, either in the source unit, one of the cables, or a speaker.
If you have a spare cable, try swapping out the existing cables one at a time, as this may help you identify the source of the fault. Basically, if changing a piece of equipment makes the fault go away, then that piece of equipment is probably at fault.
If you can give us a little more detail about how your speakers are connected together, this may shed some extra light on how we can help.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Hi Steve and Alex,
Thanks for trying to help....
So, my speakers are connected to BC1 - digital back (surround sound back) left one is conected on left PL plug and right on is on right....and then from BC1 - ML cable to converter 1611 - from 1611 data cable to aux on BS2300.
I've checked data cable from BS2300 ( I have spare one so I've changed and nothing happened) and it seams to me this is not a problem. Also powerlink cables are ok cos when I playing from other source everything is ok.
I didn't check ML cable, I don't have spare one ....
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
no one ?
Still waiting for Keith ....
with grappa !
Page 1 of 1 (12 items)
