Hi, i just install my father's beogram 4000 in my living room.
It's in mint condition (first-hand ;-)) and i just had to
change the bulb for the 33 speed adjustement screw, do
some setup (heigt adjustement, cleaning) and everything working perfectly!
BUT i can't connect it to my Besound at because i
don't have a riaa phone preamp for the moment ( looking
at the REGA fono mini or cambridge audio 540/640P)
For the ground (earth) do i need to change the power plug
for a grouded one? The beosound 9000 has no ground
connection. If so, should i make a ground connection
between the beogram and the phono preamp though?
Last question, do you think it's worth to change the
din cable for a direct RCA cable instead of original cable and din to RCA adaptator cable?
Beosound 9000 & Beolab 8000 & Beogram 4000
