moxxey:
Same here, I want to know this info too.
I also want my dealer to contact me to say they have this fix. So far, no pro-active contact. If they don't bother, I hope they realise I'm unlikely to buy kit from them, soon.
hi there buddy well one of my dealers called me up and said that the update was being released and it is meant to be a fix all for the recent problems that have arrisen
i am told:
4.24a caused problems with crashing and a fix came out that meant you had an update and had to have the scart lead connected all the time as the sync was going out but did not happen pre 4.24a.
5.02 causes problems with the tv needing a scart lead and HDTV link problems when using sky hd via a link room and the tv in some cases turns off the sky box for no reason and sometimes does not turn the sky box on at all.
i am told 5.08 fixes the need for a scart lead so this can be removed once again and only use HDMI as all other tv's do, i am also todl that there is a new puc called thompson HD for use wiht SKY HD that works differently to Pace SKY+ so this shoudl solve some issues too.
hopfully this will be a final fix as i have had my tv over a year and its been "broken" since it came out of the box.
get your dealer to speak to technical as im todl this is where the info came from.
Beovision 7 MKIV (Blu Ray)
Beolab 9
Beolab 6000
Beo 4
Beocenter 9300
Apple TV
SKY HD
Optoma HD65 Projector
Lintronic TT455-RT-238
Beovision 3 MKII
