Latest post 02-16-2009 12:49 PM by Medogsfat. 11 replies.
Page 1 of 1 (12 items)
  • 02-16-2009 10:17 AM
    Beomaster 5500 AUX with Beolink 1000?
    Is it possible to choose the AUX source of the Beomaster 5500 with the Beolink 1000. If yes, then how?
  • 02-16-2009 10:24 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beomaster 5500 AUX with Beolink 1000?
    Shift - radio
    Welcome to BeoworldSmile
    Chris.
  • 02-16-2009 10:27 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Shift + A.Tape Smile
     Weekly top artists:
  • 02-16-2009 10:29 AM In reply to
    • Alex
    • Posts 2,990
    FWIW, Shift + A.Tape and Shift + Radio do the same thing.
     Weekly top artists:
  • 02-16-2009 10:32 AM In reply to
    Thank you for the quick reply and for the warm welcome.
  • 02-16-2009 10:34 AM In reply to
    Alex:
    Not entirely. Shift A.Tape switches to the Tape 2 light, and Shift Radio switches to the AUX light.
  • 02-16-2009 10:40 AM In reply to
    • Alex
    • Posts 2,990
    I should have posted more clearly - sorry. I meant they both enable the same input.
     Weekly top artists:
  • 02-16-2009 10:54 AM In reply to
    Alex:
    Is Tape 2 the same as Aux then Alex?
    Regards Graham
  • 02-16-2009 10:57 AM In reply to
    • Ignace
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Yes, on Beomaster 5500 it is the same input / socket.
    On Beomaster 4500 : AUX & TV share the same input and Tape 2 & Phono.
  • 02-16-2009 11:18 AM In reply to
    Ignace:
    Well........you live and learn!
    Regards Graham
  • 02-16-2009 11:35 AM In reply to
    • Alex
    • Posts 2,990
    I wonder whether there are actually any differences? Maybe it's something to do with the datalink signals?
    On the 6500 & 7000 models, they activate the same light.
     Weekly top artists:
  • 02-16-2009 12:49 PM In reply to
    • Medogsfat
    • Posts 4,045
    I think it matters if you connect a Beovision to this input. IIRC you need to use shift/radio and a number to be able to use the system speakers.
    Chris.
