Latest post 02-15-2009 2:44 PM by joeyboygolf. 8 replies.
Page 1 of 1 (9 items)
  • 02-15-2009 8:46 AM
    Mono Only on Beosound 9000 and Beolab 6000
    Hi
    I have just installed my system after moving home and I have found a problem between the Beosound 9000 and Beolab 6000.
    Using the Powerlink cables to connect them together, I can only get the left hand channel, If you select Left on one speaker and Right on the other the right side has no sound.
    You have to set them both to the Left for both of them to work, but then of course you hear only the left side of the stereo only.
    I have tried them on both connectors seperatly and with them looped through but still get the same results.
    If you listen to the other speakers in the link rooms they are all fine.
    Has anyone any ideas?
    Regards
    Nigel
  • 02-15-2009 10:14 AM In reply to
    Re: Mono Only on Beosound 9000 and Beolab 6000
    Check by using one P/L cable and one speaker only. Switch the speaker from left to right channel. Sound from both channels?
    Now swap either the speaker or the cable and repeat. Carry on until you have checked everything and we can eliminate cables and speakers.
    Next I would suspect some sort of M/L problem and suggest that you unplug from the mains for a few minutes before re-connecting.
    Let us know what happens!
    Regards Graham
  • 02-15-2009 11:51 AM In reply to
    I had similar problem with my BC1 and BL8000. They are connected to BC1 and than ML from BC1 to BS23000
    And when I try to setup both speakers L or R sometimes there are not working but when I put them on middle position there are working fine, and it seams to me that they have stereo.
    But when I try to adjuste speaker level on BC1 only right is working ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 02-15-2009 12:05 PM In reply to
    I had the same problem with some BL8000's recently, could have sworn it was the speakers but on testing with different PL cables it was down to the cable only - suspected the switch, that was my next port of call.
  • 02-15-2009 12:18 PM In reply to
    In my case is like this:
    When I put left speaker on L and right on R, right is not working ...
    But when I put left on L and right on middle position everything is working ok, stereo signal good balance ....
    in bouth speakers same case ....
  • 02-15-2009 12:47 PM In reply to
    nmartin771:
    Surely the middle position is RIGHT???
    The positions are LEFT - RIGHT - LINE
    I've just checked a pair
    Regards Graham
  • 02-15-2009 12:51 PM In reply to
    aaaaaaaaa,
    I'm really sorry for confusing you!!!!Surprise
    Probably I didn't saw it right !
    and thought middle is position for line ... Huh?
    SORRY one more time Smile
  • 02-15-2009 1:43 PM In reply to
    Hi
    Thanks for your help problem solved, It was one of the new PL cables I purchased from Lifestyle.
    Regards
    Nigel
  • 02-15-2009 2:44 PM In reply to
    beatpoets:
    Hi
    Regards
    Nigel
    SurpriseDevil
    Regards Graham
