Hi
I have just installed my system after moving home and I have found a problem between the Beosound 9000 and Beolab 6000.
Using the Powerlink cables to connect them together, I can only get the left hand channel, If you select Left on one speaker and Right on the other the right side has no sound.
You have to set them both to the Left for both of them to work, but then of course you hear only the left side of the stereo only.
I have tried them on both connectors seperatly and with them looped through but still get the same results.
If you listen to the other speakers in the link rooms they are all fine.
Has anyone any ideas?
Regards
Nigel
