Peter :
They don't really talk to the Beoport - they talk to the computer. I use both and they both work fine. You can however only control the computer one at a time - in other words you cannot use each to listen to a different tune in different rooms simultaneously - you only have one copy of iTunes! I have the iTouch in the bedroom and the iPhone with me.
Hi again Peter and Soundproof
I knew it, the snow is falling now. Maybe we can go skiing with the kids in the weekend. The temperature is about one degree below zero outside our Beolab 3 (Kitchen).
I realise now that I wrote my text badly. Another occasion then you realise that english is not your native language
. I know that Ipod touch does not speak to Beoport but to iTunes and that there is just one source/iTunes(computer). I think though that I can read the answer I wanted between your lines. If I understand it correctly, you have two remotes that can control your iTunes, one iPhone and one iTouch? The question I intended to ask was if you lay down both of your remotes on a table and play something with cover art visible in one of the remotes, can you see the same cover art in the other one? If I phrase it like this maybe: Is it possible to have both remotes to control the same iTunes at the same time?
Sorry if i do not make myself clear
Clakke
