Latest post 05-10-2009 7:09 AM by guidovangool. 7 replies.
Page 1 of 1 (8 items)
  • 02-09-2009 1:54 PM
    • amr
    • Not Ranked
    • Joined on 01-09-2009
    • Posts 7
    Beocenter 8000 cd-problem
    I hava a beocenter 8000 with a non-working cd-player. After a look around the forum I changed a couple of resistors and a transistor that messured out of range. Now the CD spins up and keeps spining at a speed near light:), after 3-4seconds the lid opens. Before doing any "repairs" the cd did maybe move for 3/4 of a round. Anybody who have a clue?
    Wink
  • 02-09-2009 2:26 PM In reply to
    Re: Beocenter 8000 cd-problem
    Hmmmm, send the drive to Ulf ?
    I'm sure he can cure the drive....Smile
  • 02-10-2009 4:17 AM In reply to
    • amr
    • Not Ranked
    • Posts 7
    That is probably the best thing to do, but I like to try doing it myself. This is a hobby of mine. So if anybody has any suggestions about what to check out next, I am very happy for every answer...
  • 02-18-2009 6:01 AM In reply to
    • amr
    • Not Ranked
    • Posts 7
    Anybody? :)
  • 02-20-2009 7:23 AM In reply to
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    Hi Amr
    Try to clean the laser.
    Best Regards
    Loudspeaker
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 02-20-2009 7:36 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    First, do you have the right instruments, knowledge, skills and test CD's to service B&O CD decks or
    are you working on the "kitchen table" ?
    Replacing bad components is one thing. Finding out why they went bad is another.
    What was wrong with the "out of spec" components and which components were they ?
    Did you check laser current, focus control, radial balance and the presence of a clean catseye pattern ?
  • 02-27-2009 5:42 PM In reply to
    • amr
    • Not Ranked
    • Posts 7
    I am working at home, but I have opportunity to do more advanced mesuring and component checks elsewhere. I found that two 10ohms resistors where out of specs, one of them was blown(burned). After reading around on this forum I found that this resistors worked as fuse for a transistorpair. I tested the two transistors and found that one in fact was not working. So I replaced it. But the problems are still the same... This is where I found the tips about changing the transistors: -->
    http://forum.beoworld.org/forums/t/9684.aspx?PageIndex=2
    PS I dont have any test cds, but I have an extra laser and engine from an old Philps cd player.
  • 05-10-2009 7:09 AM In reply to
    If not yet solved, if the disc is spinning counterclockwise at lightspeed check T6314 on PCB 31. -9Volt. This is a SMD transistor on the back of the PCB. Servicemanual page 2-14.
    Or get a secondhand Philips CD-Player with simmilar PCB's,
