Latest post 02-06-2009 5:49 AM by Medic394. 4 replies.
Page 1 of 1 (5 items)
  • 02-05-2009 6:10 PM
    Beocenter 6 Anti- Reflex Coated Screen.
    Hi fellow members, i have a Beocenter 6 and i have noticed some milky smears on the contrast screen i have tried using a lint free cloth to remove them but no luck. Does anybody have any ideas? many thanks
  • 02-06-2009 3:34 AM In reply to
    Re: Beocenter 6 Anti- Reflex Coated Screen.
    It is recommended to use a mild window cleaning preparation - I use Windowlene!
  • 02-06-2009 4:17 AM In reply to
    Hello.
    The best way IMHO is to use a soft, barely moist cloth and wiping over the smears a few times without to much pressure. Sometimes just "breathing" against the screen and then using a dry cloth is sufficient.
    If this will not help, try a mild window cleaner (no alcohol) and spray just a little bit on the cloth. Do not apply anything on the screen! Always on a cloth or tissue.
    Regards
    Alex
  • 02-06-2009 5:21 AM In reply to
    When I clean my 7-40 screen I use a lightly moist/damp cloth and rub in a circular motion around the smear, I then polish it out with a polishing duster immediately. You need to do it quickly after rubbing the smear and also press very hard. The duster should also be a new one or a recently washed one otherwise it will just spread the smear rather than buff it out. Get this right and it works wonders and completly protects the screen. Can take a short while to do 40inches woth of screen but worth it!
    Simon.
  • 02-06-2009 5:49 AM In reply to
    Thank you all for the advise i will try some of your answers.
