Hello.
The best way IMHO is to use a soft, barely moist cloth and wiping over the smears a few times without to much pressure. Sometimes just "breathing" against the screen and then using a dry cloth is sufficient.
If this will not help, try a mild window cleaner (no alcohol) and spray just a little bit on the cloth. Do not apply anything on the screen! Always on a cloth or tissue.
Regards
Alex
