Latest post 02-09-2009 4:44 PM by Xseries. 2 replies.
Page 1 of 1 (3 items)
  • 02-04-2009 8:51 PM
    Question re: Beomaster 5000 and 5500
    Hello -
    I have a Beomaster 5000, through which I play a Beogram 1800 turntable (with RCA plugs), and a Beomaster 5500, through which I play a Beogram 4002 turntable (with a 5-pin DIN plug).  Due to the method of connection, neither of the Beomasters automatically switches to the stand-by mode when they've been dormant for a while after playing a record.  (By contrast, the Beomaster 5500 - which is also connected to a Beogram CD 5500 - goes into stand-by mode about 30 minutes after I finish playing a CD.)
    My question - no doubt rudimentary to those of a technical bent - is, Does it matter if I leave the Beomasters in Phono mode all the time, or should I manually switch them to stand-by when I'm done playing LP's, and won't be using them again for a while?  I don't know if, by leaving them in Phono mode continuously, I'm putting more "stress" on the system than if the receivers were  put in stand-by mode when not in use.
    Thanks for any advice.
    John
  • 02-05-2009 1:53 AM In reply to
    Re: Question re: Beomaster 5000 and 5500
    You will be using more power certainly so I would switch to stand by if only for that reason. I doubt it will have much effect on longevity unless the Beomasters are drifting out of spec. If either runs particularly hot, it would be worth getting it serviced.
  • 02-09-2009 4:44 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Go for standby - or even switch off (power off) at the mains (see the thread about Power Off v Standby!) if they are not going to be used for a while.
    I think I am right in saying that these amplifiers need the two extra pins (6/7) to give the feedback after 30 minutes of inactivity to then switch the whole system off.  That is why they do not power down when on the radio....
    Brian
