Latest post 01-30-2009 5:30 PM by Medogsfat. 2 replies.
Page 1 of 1 (3 items)
  • 01-30-2009 2:29 PM
    • arrann
    • Not Ranked
    • Joined on 01-26-2009
    • Kent
    • Posts 3
    LX2800
    Being a new member to Beoworld i have a LX2800 tv which will switch on to standby only and has no remote, though i have a remote with the LX2500 which works with it. Is it repairable?, is it worth repairing?. Or should i just scrap it.
        Paul
  • 01-30-2009 4:51 PM In reply to
    Re: LX2800
    Hi:
    Welcome to Beoworld!
    It is almost certainly not worth repairing in fiscal terms unless the problem is simple and you can fix it yourself. B&O CRT televisions are very cheap at the moment and will probably continue to be so. On eBay you can buy similar working televisions for <£30. Although for how long they will remain working is obviously an unknown.
    If the televison has sentimental or nostalgic value then you could of course repair it. I often do this with old computers just because it gives me something to do but this obviously does not make economic sense.
    Hope this helps
    Graham
  • 01-30-2009 5:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: LX2800
    Sad to say that Graham is rightSad
    Lovely TV's but not really worth spending money on as you can easily buy a much better LX on ebay for far less than the repair bill would be.
    eg:- a few weeks ago I bought a mint LX5500 with motorised stand, beolink 1000 remote & VX7000 video player/recorder for the grand sum of £32. I absolutely love it but if it broke down there's no way I'd spend money getting it repaired - just not worth it. It sounds like a power supply problem but I'm no expert, member nobby may be able to help as he's the CRT expert on here.
    Chris.
