1st March February 2012
Latest post 02-07-2009 11:48 AM by Medogsfat. 4 replies.
01-29-2009 11:54 AM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Beogram 4002 speed problem...
Hello guys
A couple of weeks ago, I bought the terrific Beogram 4002 deck. It works perfectly, I thought...
Some days after I wanted to listen to some 45 singles. I put the on the deck and press PLAY. It detects it all and moves the arm the groove at 45 rpm setting, but after a couple of seconds, i could hear a great speed deviation... The platter doesn't run faster than 45 RPM, but just gets that slow that there is a very audible pitch change...
please help me :(
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: Beogram 4002 speed problem...
You've already been a member for a year but since this is your first post here I would like to welcome you to Beoworld !
Fitst thing to check will normally be the belt but if the fault is only related to 45RPM and not present on 33RPM, I suppose we can rule that out. Next up is the speed setting trimmers, both the fingerwheel-operated ones on the panel and the ground-adjustment trimmers on the main printed circuit board. If not operated for a long time, they can develop oxidation (and collect dust etc.) Finally, the speed changing relay could have bad contacts.
Roll the fingerwheels back and forth a couple of times to see if it cures the fault.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hello Martin
Thank you for advice
I have something to try when I get home from the boarding school I'm at... I maybe come home in the next weekend to try the thing with the fingerwheels and adjustment trimmers If the problem doesn't fix I have to check my service manual
But it's very strange that the 33RPM setting works perfectly with no speed changes, but 45RPM...
Greetings, Søren H
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hello again. Altering the trimmers on top of the deck can't solve the problem, but the beogram only does this fault when is hasn't been playing at 45 r.p.m. in a day or so. After the first single, there isn't the problem in 'wobly' speed variance (guess I could call it Wow or flutter?).
But I have strict orders from my father(an expirienced electrician) that i must not open the deck, even if I show him how easy it is to (dis-)assemble the deck. He might be scared that it may be impossible to put it back together again.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
I wouldn't worry about that, probably the easiest record decks in the world to access. Reassembly is a simple reverse of disassembly.
Chris.
Page 1 of 1 (5 items)
