Latest post 01-28-2009 5:02 PM by Steve at Sounds Heavenly. 12 replies.
Page 1 of 1 (13 items)
  • 01-27-2009 10:00 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    What is this cable used for?
    Thanks for your help.
    As far as I remember it came with my beolab 8000 and the bc 9300...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-27-2009 10:11 AM In reply to
    Re: What is this cable used for?
    record player to aux connection .... I believe.
  • 01-27-2009 10:13 AM In reply to
    actually that might be wrong, its a female cinch plug i just realized.
  • 01-27-2009 10:37 AM In reply to
    • kallasr
    • Posts 1,077
    There were two cables included, so it has to be something with speakers?
    Ralf
  • 01-27-2009 10:42 AM In reply to
    Plug it in the "AUX", and hook up any other equipment using regular RCA cables which are usually male-male. Therefore easier to get this adapter as a female version.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-27-2009 10:44 AM In reply to
    The separate wire is for grounding between units. Could be a converter for a Beogram record player equipped with DIN out, to enable you to connect it to an amp or stand-alone RIAA record player preamp.
    Looked for similar cables at Flashbacksales, check at the bottom: http://www.flashbacksales.co.uk/acatalog/headphone-amp-5-Pin-din-phono-rca-Cables.html
  • 01-27-2009 11:06 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    soundproof:
    I think Soundproof is closest, but has it backwards.  This cable allows you to conect a non-B&O (or non-DIN B&O) turntable to a BeoCenter/Master/Sound with an RIAA-Phono input.  Those turntables use a male RCA cable and usually require a seperate ground point.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 01-27-2009 11:09 AM In reply to
    Yes, but let's not confuse him, the cable will also work fine with an iPod, TV or any other source, just leave the ground cable unused.
    -Andreas
  • 01-27-2009 11:14 AM In reply to
    • Russ
    • Posts 641
    Hi Andreas,
    Not intending to be confusing, just precise.  Geeked  There is a different cable intended for use with 'line-level' devices such as you describe, but it's grounding/earthing characteristics are different.  Depending on whom you ask, the two are in fact not interchangable.
    McLean, VA USA
  • 01-27-2009 11:25 AM In reply to
    You are right Russ.
    -Andreas
  • 01-27-2009 11:58 AM In reply to
    Was thinking about that, with the female plugs! Think you're right, from something with RCA to a B&O unit, connecting with the DIN.
  • 01-27-2009 2:30 PM In reply to
    I would suggest it is for attaching a record player. Not much use for the 9300 as it does not have an RIAA unless it was for attaching an external RIAA to the 9300 after a record player was attached to the RIAA. Especially if the RIAA had captive RCA plugs.
  • 01-28-2009 5:02 PM In reply to
    Hi everyone,
    Sorry to arrive at this post so late in the day!  To summarise, this type of cable is intended to add a non-B&O turntable (specifically those such as Rega Planar 3 with captive RCA leads) to an earlier type Beomaster or BeoCenter that has a built-in RIAA pre-amplifier.  However, as mentioned previously, it can also be used to connect other line level sources with captive or intermediate RCA cables (eg. TV/DVD/iPod dock, etc.) into most B&O audio systems using the Aux or Tape inputs.
    I get very few requests for this configuration of cable (ie. Female RCA to 5 pin DIN), as most requests for leads of this type are for Male RCA to 5 pin DIN cables.  However they can be useful in the circumstances described above.
    Hope this helps! Cool
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
