1st March February 2012
01-27-2009 10:00 AM
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
What is this cable used for?
Thanks for your help.
As far as I remember it came with my beolab 8000 and the bc 9300...
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
Re: What is this cable used for?
record player to aux connection .... I believe.
jk1002
- Boston USA
- Posts 1,620
actually that might be wrong, its a female cinch plug i just realized.
kallasr
- Posts 1,077
There were two cables included, so it has to be something with speakers?
Ralf
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Plug it in the "AUX", and hook up any other equipment using regular RCA cables which are usually male-male. Therefore easier to get this adapter as a female version.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
soundproof:
I think Soundproof is closest, but has it backwards. This cable allows you to conect a non-B&O (or non-DIN B&O) turntable to a BeoCenter/Master/Sound with an RIAA-Phono input. Those turntables use a male RCA cable and usually require a seperate ground point.
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
bayerische
- Helsinki, Finland
- Posts 3,593
Yes, but let's not confuse him, the cable will also work fine with an iPod, TV or any other source, just leave the ground cable unused.
-Andreas
Russ
- Posts 641
Hi Andreas,
Not intending to be confusing, just precise. There is a different cable intended for use with 'line-level' devices such as you describe, but it's grounding/earthing characteristics are different. Depending on whom you ask, the two are in fact not interchangable.
McLean, VA USA
bayerische
- Helsinki, Finland
- Posts 3,593
-Andreas
soundproof
- Posts 2,340
Was thinking about that, with the female plugs! Think you're right, from something with RCA to a B&O unit, connecting with the DIN.
Peter
- Joined on 02-12-2007
- Posts 9,572
I would suggest it is for attaching a record player. Not much use for the 9300 as it does not have an RIAA unless it was for attaching an external RIAA to the 9300 after a record player was attached to the RIAA. Especially if the RIAA had captive RCA plugs.
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi everyone,
Sorry to arrive at this post so late in the day! To summarise, this type of cable is intended to add a non-B&O turntable (specifically those such as Rega Planar 3 with captive RCA leads) to an earlier type Beomaster or BeoCenter that has a built-in RIAA pre-amplifier. However, as mentioned previously, it can also be used to connect other line level sources with captive or intermediate RCA cables (eg. TV/DVD/iPod dock, etc.) into most B&O audio systems using the Aux or Tape inputs.
I get very few requests for this configuration of cable (ie. Female RCA to 5 pin DIN), as most requests for leads of this type are for Male RCA to 5 pin DIN cables. However they can be useful in the circumstances described above.
Hope this helps!
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Page 1 of 1 (13 items)
