Latest post 05-26-2007 5:13 AM by Jeddy. 7 replies.
Page 1 of 1 (8 items)
  • 05-24-2007 11:40 AM
    • Jeddy
    • Not Ranked
    • Joined on 05-24-2007
    • Hampshire, UK
    • Posts 17
    IR Codes for Beo4
    Does anyone have  any information about IR codes for a Beo4 please?
    I've managed to learn all the ones I want with my universal remote, however although some like volume up and down work, they don't seem to work in a repeat fashion if I hold the button down (this isn't  a feature of the Philips Pronto universal remote as it works with repeat on other AV products).
    It is almost like there is one code for up one step in volume and another code for contintuous up in volume (if there is I can't learn it or it doesn't work when I play it back, I tried that).
    If anyone has any information on how this works that would be appreciated.
    Thanks,
    Jeddy
  • 05-24-2007 12:33 PM In reply to
    Re: IR Codes for Beo4
    With the Beo4 the volume up is code 00 xx 60 where "60" is code for volume up and "64" is the code for volume down.
    If you hold your finger on the Beo4 volume up or down button, it actually keeps sending the code 60 or 64 with a delay between each code transmission until you take your finger off the button.
    There is not a different code for repeat volume up or down.
    Regards Keith....
  • 05-24-2007 12:43 PM In reply to
    • Jeddy
    • Not Ranked
    • Hampshire, UK
    • Posts 17
    If I understand you, you are saying that a one up on volume would be 00 xx 60 for one step in volume or 00 xx 60 60 60 60 etc. for multiple steps?
    I'm guessing most manufacturers maybe repeat the whole packet (e.g. repeated 00 xx 60 00 xx 60 etc.) rather than just one bit of  it which is where I may be falling down?
    I have to confiess I don't understand the codes at all, my pronto learned the volume up code as
    7000 0009 0000 000D 0003 0017 0005 0005 0001 0005 0004 0004 0004 0004 0004 0004 0004 0004 0004 0003 0004 0005 0004 0004 0004 0004 0002 0005 0010 0994
    and down as
    7000 0009 0000 000D 0003 0017 0005 0005 0001 0005 0004 0004 0004 0004 0004 0004 0004 0004 0004 0003 0004 0005 0004 0003 0005 0004 0002 0005 0010 0994
    so I'm not quite sure how that translates from the format you have used.
    Thanks Jeddy
  • 05-24-2007 12:59 PM In reply to
    I will need to study your codes because I do not really understand what you have sent
    My numbers are in Hex meaning 4 bits is one digit from 1 to F where "1111" is "F" and "0000" is 0
    It looks as if yours are in Hex as well because I see "9" and "D" in a couple of records
    If I remember correctly the format went something like 4 bits is header, then 5 bits is the device address and 8 bits relates to the data being sent to the device.
    Regards Keith....
  • 05-24-2007 6:22 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    You can find complete CCF files for Bang and Olufsen for the philips Pronto here:
     http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=bangolufsen
  • 05-25-2007 8:21 AM In reply to
    • Jeddy
    • Not Ranked
    • Hampshire, UK
    • Posts 17
    Thanks for that post from NZ (brings back very pleasant memories of my 5 weeks there earlier in the year), although I'm afraid that life is never that simple.
    I used those codes from that .ccf successfully with by previous remote (RU940) and they worked. They also worked on my current remote (RU950) until I upgraded the firmware. At this point they stopped working however I was now able to learn them directly (one of the firmware improvements - along with others I wouldn't want to live without). The catch being that the B&O codes I am now able to learn don't work with repeat function (even if I extend the duration of the IR in the software).
     As an example, instead of the volume up listed above, it used to show as
    0000 0009 0016 0015 005b 0546 005b 0546 005b 1bc0 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1083 005b 0ae4 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1622 005b 3d82 005b 0546 005b 0546 005b 1bc0 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1083 005b 0ae4 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1622
    quite how two so different codes can both operate the B&O volume is beyond me.
    Jeddy
  • 05-25-2007 12:05 PM In reply to
    Here is what I know about Pronto B&O codes in the 7000 format. Maybe someone else can decipher the unknown parts.
    This is how the Prono hex maps to pulse times and what they mean...
    0005 = T1 3.125 mS = 0 bit
    0004 = T2 6.250 mS = Same as last bit
    0003 = T3 9.375 mS = 1 bit
    0002 = T4 12.50 mS = Stop bit
    0001 = T5 15.62 mS = Start bit
    So...
    7000 Special Code
    0009 455 kHz
    0000 ???
    000D B&O?
    0003 ???
    0017 Length (23)
    0005 AGC
    0005 AGC
    0001 Start
    0005 0
    0004 0
    0004 0
    0004 0
    0004 0
    0004 0
    0004 0
    0004 0
    0004 0
    0004 0
    0003 1
    0004 1
    0005 0
    0004 0
    0003 1
    0005 0
    0004 0
    0002 Stop
    0005 ???
    0010 ???
    0994 ???
    Data in binary...
    0 0000 0000 0110 0100
    hex...
    0    0    0    6    4
    Interpetation...
    000 = Video address
    64 = Volume down command
    The directional and colored buttons send one code when pressed, and then another code when held. The volume buttons don't - they repeat the same code.
  • 05-26-2007 5:13 AM In reply to
    • Jeddy
    • Not Ranked
    • Hampshire, UK
    • Posts 17
    Ah, well explained, I'd seen that mentioned elsewhere but the explanation was beyond me on that website - your example makes it crystal clear.
     I think I'm now sorted actually. I found after a firmware upgrade on my remote that the remote has now got codes for B&O in its database (hurah) and after a bit of playing around with minimum duration I've now got it to work as desired.
    Thanks for your help guys.
    Jeddy
