Thanks for that post from NZ (brings back very pleasant memories of my 5 weeks there earlier in the year), although I'm afraid that life is never that simple.
I used those codes from that .ccf successfully with by previous remote (RU940) and they worked. They also worked on my current remote (RU950) until I upgraded the firmware. At this point they stopped working however I was now able to learn them directly (one of the firmware improvements - along with others I wouldn't want to live without). The catch being that the B&O codes I am now able to learn don't work with repeat function (even if I extend the duration of the IR in the software).
As an example, instead of the volume up listed above, it used to show as
0000 0009 0016 0015 005b 0546 005b 0546 005b 1bc0 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1083 005b 0ae4 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1622 005b 3d82 005b 0546 005b 0546 005b 1bc0 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1083 005b 0ae4 005b 0546 005b 0ae4 005b 0ae4 005b 0ae4 005b 0ae4 005b 1622
quite how two so different codes can both operate the B&O volume is beyond me.
Jeddy
