hi all,
in the midst of cleaning up my beo, i have split up my bm1000's. one in teak w/ matching teak 2200's is off to a brother-in-law, though he doesn't know it yet! the other in rosewood w/ its matching rw 2200's has found its way to my nightstand replacing my bc9300 that i used only w/ headphones. to the question: the bm1000 does not have a headphone out; anyone ever rigged anything to run headphones from the speaker2 outs? any other options?
thanks in advance!
++++edit++++
sometimes i can be a real dolt...
i not only have one, but two niles audio switch plates that will do this! bought them long ago and forgot i had them.
if anyone is interested... you basically wire the speaker1 outs into the switch. then there are 2 outs that are switch controlled. one is a 2pair back to your speakers, the other is a TRS female for headphones. not exactly my intent when i wrote the post... but i might as well use them! i could run speaker2 to the other side of the bed -and viola -dual headphones!
of course, i'd love to hear about other options... w/o all the work needed for the niles option. a simple lead would be nice!
