Latest post 01-25-2009 10:38 AM by The_Beonic_Man. 4 replies.
Page 1 of 1 (5 items)
  • 01-23-2009 4:24 PM
    BeoSound 3 - Problems with Bit Rate
    Hi all,
    It seems that my BeoSound 3 doesn't want to play WMA files at a Lossless bit rate. I wasn't aware until now that there were these kinds of restrictions. Any thoughts? Anyone else tried with different results? I'll try them at 192 when I get a chance and hope they'll play. If not, then it'll have to be back to 128. Given the nature of the BeoSound 3 I am sure I wouldn't have noticed much of a difference anyway but it was an interesting exercise. All it does when you press the A.MEM button is count up through the number of files on the SD Card and displays 'A - 0' briefly before switching off.
    Simon.
  • 01-24-2009 1:09 AM In reply to
    Re: BeoSound 3 - Problems with Bit Rate
    BeoSound 3 specs as follows:
    MP3  32 kbps to max. 320 kbps
    WMA 32 kbps to max. 192 kbps
  • 01-24-2009 2:36 AM In reply to
    This is one of many things that B&O should improve in its present product range: have products that all speak the same language!
    If people have a BeoSound 3 in the garden, a Serenata phone, and a BeoSound 4 in the house, what bitrate are they supposed to select when ripping their CDs???
    None of the present SD/flash memory based products have the same specs, I listen to lossless WMA on my Serenata, but will never buy a BS3 or a BS4, simply because I won't be able to listen to my audio files on them!
    Is it so hard to update all BeoSounds 2/3/4 and 6 to play lossless WMA files? Or are we supposed to partition our hard drives to have half of it in lossless, and the other half in 192 kbps? I'm sure almost 80% of B&O owners don't know how to partition a hard drive..
    Reunion Island is greeting you!
    Filed under:
  • 01-25-2009 1:21 AM In reply to
    • saf
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 458
    I share your frustrations, Simon (went through similar 'experiences' recently) - and, of course, one can only agree with Chris mentioning the current sorry state of things ... pitty as I personally like the BS3 a lot!
    Still, there's more to the problems according to B&O:
    BeoSound 3 cannot play files with embedded covers
    Information valid for: BeoSound 3, BeoSound 3 MK II
    If you rip a CD in BeoPlayer version 4.65 or higher, the file cannot be played back from an SD card loaded in
    BeoSound 3.
    When BeoPlayer 4.65 or higher rips a CD, it incorporates the cover with the file via AMG, and when this
    information is included in the file on the SD card, it cannot be played on BeoSound 3.
    The only solution is to rip a CD without the AMG function - either by using a BeoPlayer version prior to
    version 4.65, or by removing the network connection when ripping CDs, or by using a different programme
    to rip your CDs.
    Sad
  • 01-25-2009 10:38 AM In reply to
    Hi saf,
    Many thanks for the info. Will take note. All the best...
