1st March February 2012
Latest post 01-24-2009 5:54 PM by stefan. 12 replies.
01-22-2009 9:36 AM
avus17
- Joined on 04-16-2007
- Posts 336
BeoSound 5 & BeoMaster 5 more questions, need answers
First question:
Why there are two units: BeoSound 5 controler and BeoMaster 5? BeoMaster 5 could fall away as it is only a 500 GB storage device. Instead of BeoMaster 5, the control unit could directly be connected to the PC, as today we have PCs with 1 tera or more of disc space. This way a lot of cables would fall away and also the whole system could be cheaper. It would also be more simple to add mp3 files/radio stations to BeoPlayer on PC and play them via the control unti, so no riping from PC to BeoMaster would be needed. This could also be done with jpeg files and web sites.
Do you think some PC programme with a special BeoPort could be arranged by some hobby electrotechnician to make the BeoMaster unnecessary as it is a big and ugly black box?
Second question:
Why there are so many cables from the BeoSound 5 control unit to the BeoMaster (power, USB and video cable)? This makes it almost impossible to store BeoMaster 5 far away in some other room together with the PC. Or are there 10 or more meter triple-cables available. But there must definitively be three cables from BeoSound 5 control unit to the BeoMaster 5 box, if I understand the user guide correctly.
Third question:
How are the Net.Radio stations added to the BeoMaster 5. Are the radio sides defined in BeoPlayer? I guess only free radio stations can be listened to.
Fourth question:
BeoSound 5 supports playback of WMA lossless files. Can this be assured also if MP3 music is uploaded from the internet? I guess bits go missing with this compressed MP3 music. So only CD files riped to WMA format contain this bits. Am I right?
Fifth question:
Can BeoMaster 5 be operated via Beo4/5 and content be displayed on the TV with no need of BeoSound 5? Can BeoMaster 5 be stored in BeoVision 9 housing no matter of BeoVision 9 version?
jk1002
- Boston USA
- Posts 1,620
Re: BeoSound 5 & BeoMaster 5 more questions, need answers
Sixth question:
Can it play Dj mixes and classics without the short pause between the songs that some MP3s do (earlier Ipods)
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
question 7:
if you opt for beomaster 5 only can you access N.Nusic on the tv as you can with the beomedia 1 and does the interface via the tv allow album art???
has anyone got theirs yet?
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
I posted a similar thread on B&Os website, named "why BeoSound 5?", the questions are almost the same, maybe slightly more provocative
Clearly I don't understand why BeoSound 5 was called like that, they could have named it Master Control Panel 5, as this is all that it does (with lots of cables)..
Reunion Island is greeting you!
Lorup
- Joined on 10-13-2007
- Denmark
- Posts 39
seanklemis:
question 7:
Yes, you can, it is the same as BeoMedia
BeoVision 7-40 MKII, BeoSound 5, BeoLab 5
IngvarW
- Joined on 10-09-2007
- Sweden
- Posts 108
Hello, my brand new BS5/BM5 arrives on monday. Just now i´m trying to fint out how the installation of Beoplayer 5.00 acctually will be made.
I stay in touch
brgds ingvar
Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
stefan
- 200 miles from Struer
- Posts 1,733
Hi Ingvar,
where did you find Beoplayer 5.00 ?
Stefan
stefan
- Posts 1,733
Yes, thanks. Beoplayer 5.00 will be delivered with BM5.
Stefan
jk1002
- Boston USA
- Posts 1,620
So what happens if I have Beomaster 5 connected to the TV and Beosound 5 as well? How does it know if I want to use TV versus Beosound 5 when pushing NetMusic on the remote?
I am somehow guessing that one "looses" the TV option when you add BS5 to the BM5.
Robert
- Joined on 06-13-2007
- Northern Ireland
- Posts 362
JK, my understand was that BM5 was set as, say, "PC", on your TV's connections. You therefore press PC on your remote which brings up the beomedia interface on your tv. You then can navigate and use GO to access your source be it NMUSIC or whatever. Although i'd presume the NMUSIC and NRADIO commands work for both BM5 and BS5. Someone will clarify this no doubt.
Robert
IngvarW
- Sweden
- Posts 108
If I have read the manual for Beoplayer right it depends on how you set it up and if they are in the same room. n.radio and n.music will appear on the BS5 and Photo and web can be accessed via the TV.
Ingvar
stefan
- Posts 1,733
Robert is right. BM5 is set up as PC to your TV (videomaster). If you press PC, your Beovision will turn on, and you have four sources: N.MUSIC - N.RADIO - PHOTO - WEB.
If you navigate the cursor to N.MUSIC and press GO, the BS5 will turn in addition to the TV.
If you press N.MUSIC your TV will stay off, BS5 will come up and starts playing the same track you listened to the last time you had N.MUSIC activated.
BTW one improvement for me is, that BM5 turns to SPEAKER 2 mode when you activate N.MUSIC or N.RADIO in PC mode.
Stefan
Page 1 of 1 (13 items)
